03-03-2023, 03:22 PM | #1 |
Rear Motor Mounts
Has anyone replaced the rubber pads to the stock rear motor mounts with engine in car and if so what is the degree of difficulty?
03-03-2023, 03:37 PM | #2 |
Re: Rear Motor Mounts
Frame spreader, or a bottle Jack helps. Pull the floor boards.
03-03-2023, 03:50 PM | #3 |
It is not too difficult, I went back to original mounts from floaters so it was somewhat different but not much.
03-03-2023, 03:52 PM | #4 |
Side-mounted spare tires make this more difficult... Found this out when trying to convert stock mounts to floater-motor-mounts. The side spare mount does not allow the motor mount to be moved aft and out.
03-03-2023, 08:41 PM | #5 |
Thanks for the advice guys. I'll just loosen them up and do one side at a time. We'll see how it goes.
03-04-2023, 12:52 AM | #6 |
03-04-2023, 01:35 AM | #7 |
You may have to loosen the cowl bolts to allow the frame to spread.
03-04-2023, 02:21 AM | #8 |
I have done it. It does test your patience -- a lot!
03-04-2023, 09:05 AM | #9 | |
03-04-2023, 09:05 AM | #10 |
52 years ago I changed the rear mount rubbers, a little foggy how I did it LOL. The new rubber didn’t help my issues that much, recently changed to cast iron float a motor that really helped!!!
03-04-2023, 09:08 AM | #11 |
03-05-2023, 05:26 PM | #12 |
I changed mine about 6 months back and I'm no expert mechanic. As I recall, all went slow but well.
03-06-2023, 10:44 AM | #13 |
Removing and installing the mounting bolts use a 1/4" rachet and adapter on the socket to turn it in and out much easier.
03-06-2023, 11:18 AM | #14 |
I would recommend removing the passenger side motor mount completely first, because there is more room to work. Then remove and replace the driver's side motor mount. when that is done, finish replacing the passenger side motor mount. You will have to jack up the motor to take the weight off of the motor mounts.
Bill Cilker, Jr Unrestored 190A Victoria 45B, 160B & 189A Victoria Association President |
03-06-2023, 01:20 PM | #15 |
03-06-2023, 01:22 PM | #16 | |
03-08-2023, 03:28 PM | #17 |
You can do it while the engine is in the car, but a frame spreader sure is a nice thing to have.
Here is a video about how it all goes together: https://www.youtube.com/watch?v=ucAb...S61UN&index=19
1931 Murray Town Sedan. Black body with Apple Green pin stripe. 1923 Model T Touring with electric start. Low radiator Cincinnati, Ohio Last edited by jwilliams81; 03-08-2023 at 03:46 PM. |
