06-20-2016, 01:54 PM | #1 |
Is this a crack ?
I opened the hood today to check the oil today,and I never noticed a crack behind the oiler filler tube. Or is it a scratch in the paint it's not leaking anything at this time.
31 Tudor 66 Bonneville 57 Chevy pickup 27 T roadster pick up Last edited by JOHN CT; 06-20-2016 at 01:59 PM. |
06-20-2016, 02:00 PM | #2 |
Re: Is this a crack ?
Hard to say just through a picture.
06-20-2016, 02:06 PM | #3 |
Probably a scratch. Cracks usually have water/rust stains from the leaking when they get hot and leak. Is your water level going down? Does it run hot? Next time you have it out for ride throw open the hood and see. However! The left side of the block, just under the head is one of the spots to look for cracks, but I think they're usually horizontal, not vertical.
Terry |
06-20-2016, 02:07 PM | #4 |
I would try and clean the paint off that area to have a better look.
_________________________________________ 1931 Ford Model A Tudor 1930 Ford Model A Deluxe Roadster 1930 Ford Original Rolling Chassis- Restoring |
06-20-2016, 02:12 PM | #5 |
Stick a magnet next to the area and sprinkle some iron filings over the spot, if it's a crack the filings will line up showing the damage.
06-20-2016, 03:19 PM | #6 |
31 Tudor 66 Bonneville 57 Chevy pickup 27 T roadster pick up |
06-20-2016, 03:30 PM | #7 |
Duct tape fixes everything............. :-)
06-20-2016, 03:36 PM | #8 |
Usually block cracks run lengthwise, not vertical like this one might be. Like some above posted, wire brush the area and see what is beneath the area that might be a crack.
Rusty Nelson |
06-20-2016, 05:08 PM | #9 |
If it aint leaking leave it alone
06-20-2016, 08:32 PM | #10 |
If you always use antifreeze I'd guess you have a scratch in the paint.
If you are a water only user, I'd not only worry about a crack, but also the circulating rust. I also see horizontal cracks on blocks, and don't ever recall a vertical crack. |
