Old 09-29-2011, 04:47 AM   #1
Rem
Rem's Avatar
Default 1938 - 1940 frame swap
I understand that '38 and '40 frames are 'similar', but are the crossmembers, transmission mount brackets, etc., all the same? Will a '40 drivetrain bolt straight into a '38 chassis, and the body just drop straight on top?
Thanks in advance.
Rem is offline   Reply With Quote
Old 09-29-2011, 06:37 AM   #2
Cecil/WV
Cecil/WV's Avatar
Default Re: 1938 - 1940 frame swap
It's the same frame.
Cecil/WV is offline   Reply With Quote
Old 09-29-2011, 06:49 AM   #3
jimTN
I believe you will have to rework some fender pan bolt holes and the front crossmember to accept the 40 forked brace. Drive train will work fine. There will be some slight modification required to use the 40 pedal bracket and linkage.
Old 09-29-2011, 07:19 AM   #4
Rem
Rem's Avatar
Thanks guys. JimTN, on the pedals, is the main difference in the clutch pedal and linkage? I think I have some '39 pedals and bracket, if they're easier to use, although would that then cause problems with the column shift linkages?
Old 09-29-2011, 07:53 AM   #5
37 Coupe
37 Coupe's Avatar
The 39 deluxe and 40 Fords have a different ,deeper front crossmember than 39 standard and earlier frames that had fan up on generator.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 09-29-2011, 08:44 AM   #6
Big Earl
Big Earl's Avatar
The radiator mounts differ as well between 38 and 39
Big Earl is offline   Reply With Quote
