06-14-2023, 11:19 AM | #1 |
Rear wheel bearing snap ring
How do I remove the rear wheel bearing snap ring? I have 4 different snap ring pliers (2 internal & 2 external) and none work.
06-14-2023, 11:35 AM | #2 |
Re: Rear wheel bearing snap ring
Take a flat blade screw driver and pry or tap the beveled end of the ring outward till one edge begins to come out. Then simply pry easily around till it comes out.
Bob from Northport Northport, Michigan |
06-14-2023, 12:03 PM | #3 |
Yep, I have just used the small flat blade screwdriver too.
1931 Murray Town Sedan. Black body with Apple Green pin stripe. 1923 Model T Touring with electric start. Low radiator Cincinnati, Ohio |
06-14-2023, 07:57 PM | #4 |
I use a sharp centre punch to make an indent as close as I can get it to the hub and close to one end of the clip, then a scriber to prise the end out of the groove.
Before refitting it, I grind the end of the clip so that there is somewhere for a screwdriver to get a grip next time.
06-15-2023, 06:43 PM | #5 |
Dave / Lincoln Nebraska |
