Old 03-03-2023, 03:22 PM   #1
arnhemmer
Default Rear Motor Mounts
Has anyone replaced the rubber pads to the stock rear motor mounts with engine in car and if so what is the degree of difficulty?
arnhemmer is offline   Reply With Quote
Old 03-03-2023, 03:37 PM   #2
Brentwood Bob
Default Re: Rear Motor Mounts
Frame spreader, or a bottle Jack helps. Pull the floor boards.
Brentwood Bob is offline   Reply With Quote
Old 03-03-2023, 03:50 PM   #3
J Franklin
J Franklin's Avatar
It is not too difficult, I went back to original mounts from floaters so it was somewhat different but not much.
Old 03-03-2023, 03:52 PM   #4
DJ S
DJ S's Avatar
Side-mounted spare tires make this more difficult... Found this out when trying to convert stock mounts to floater-motor-mounts. The side spare mount does not allow the motor mount to be moved aft and out.
DJ S is offline   Reply With Quote
Old 03-03-2023, 08:41 PM   #5
arnhemmer
Thanks for the advice guys. I'll just loosen them up and do one side at a time. We'll see how it goes.
Old 03-04-2023, 12:52 AM   #6
lrf
Recently I read that you use a bolt that is one inch longer than the stock bolts. This one longer bolt is easier to thread a nut on and pulls the parts together when the new rubber is thick. You tighten the nut then put and tighten the stock two bolts and nuts. Now remove the long bolt and replace with the stock bolt and nut. Don't forget the cotter pins.
lrf is offline   Reply With Quote
Old 03-04-2023, 01:35 AM   #7
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
You may have to loosen the cowl bolts to allow the frame to spread.
Old 03-04-2023, 02:21 AM   #8
CarlG
CarlG's Avatar
I have done it. It does test your patience -- a lot!
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-04-2023, 09:05 AM   #9
arnhemmer
That's a great idea, thanks
Old 03-04-2023, 09:05 AM   #10
Big hammer
52 years ago I changed the rear mount rubbers, a little foggy how I did it LOL. The new rubber didn’t help my issues that much, recently changed to cast iron float a motor that really helped!!!
get a bigger hammer tap done
Old 03-04-2023, 09:08 AM   #11
arnhemmer
CarlG, The one thing I do have is a alot of patience when it comes to working on the "A". Thanks again guys for your suggestions.
Old 03-05-2023, 05:26 PM   #12
Oldgearz
I changed mine about 6 months back and I'm no expert mechanic. As I recall, all went slow but well.
Oldgearz is offline   Reply With Quote
Old 03-06-2023, 10:44 AM   #13
steve smith
Removing and installing the mounting bolts use a 1/4" rachet and adapter on the socket to turn it in and out much easier.
steve smith is offline   Reply With Quote
Old 03-06-2023, 11:18 AM   #14
Bill Cilker
Bill Cilker's Avatar
I would recommend removing the passenger side motor mount completely first, because there is more room to work. Then remove and replace the driver's side motor mount. when that is done, finish replacing the passenger side motor mount. You will have to jack up the motor to take the weight off of the motor mounts.
Bill Cilker, Jr
Unrestored 190A Victoria
45B, 160B & 189A
Victoria Association President
Bill Cilker is offline   Reply With Quote
Old 03-06-2023, 01:20 PM   #15
arnhemmer
Thanks for the hint Steve.
Old 03-06-2023, 01:22 PM   #16
arnhemmer
Thanks Bill for the suggestion and thanks to all for the various ideas.
Old 03-08-2023, 03:28 PM   #17
jwilliams81
jwilliams81's Avatar
You can do it while the engine is in the car, but a frame spreader sure is a nice thing to have.
Here is a video about how it all goes together:
https://www.youtube.com/watch?v=ucAb...S61UN&index=19
1931 Murray Town Sedan. Black body with Apple Green pin stripe.
1923 Model T Touring with electric start. Low radiator
Cincinnati, Ohio
jwilliams81 is offline   Reply With Quote
