Old 04-12-2011, 08:53 PM   #1
'59Edsel
'59Edsel's Avatar
Default My Fuel Tank is Turning My Fuel Pink!
Hey guys, I've got quite the quandary. I had the fuel tank for my 1959 Edsel Ranger relined a few years back. Its been empty for most of the time I've had it since the car itself if under restoration.
I put some fuel through it the other day and this is what came out the other end.
http://i54.tinypic.com/10oe0xj.jpg
http://i52.tinypic.com/1e8mlj.jpg
Has this ever happened to anyone before? Should I have the radiator shop do my tank over again? Help.
'59Edsel is offline   Reply With Quote
Old 04-13-2011, 06:49 AM   #2
Merlin
Merlin's Avatar
Default Re: My Fuel Tank is Turning My Fuel Pink!
If you can I would try to get a hold of the place that relined it and ask them if they have had issues with their liner mix. From the pics it looks like either bad gas or liner in the tank has broken down.
Merlin is offline   Reply With Quote
Old 04-13-2011, 10:41 AM   #3
fordcragar
fordcragar's Avatar
I had a similar problem with one of my Model A's. The tank had been sealed, but was leaking around the steering bracket. I thought the color change to the gas was coming from the cork gas gauge float, but I guess it could have come from the sealant as well.
fordcragar is offline   Reply With Quote
Old 04-13-2011, 07:50 PM   #4
'59Edsel
'59Edsel's Avatar
I guess I'll take it back into the radiator shop and have them look at it. This is the second time this will be happening...to the same fuel tank! The first time they told m they didn't find anything wrong with it. Maybe its because I use 91 octane and they tested it with 87?...(If they tested it at all)
Old 04-14-2011, 10:29 AM   #5
craig
Don't know about the sealer, but it looks like the real leaded gas before 1975!
craig is offline   Reply With Quote
Old 04-21-2011, 08:21 PM   #6
'59Edsel
'59Edsel's Avatar
Well I took it in and he is going to reline it for me at no extra cost. We'll see how this turns out.
Old 04-26-2011, 04:00 PM   #7
'59Edsel
'59Edsel's Avatar
Update: Got a call yesterday and the guy says he is having difficulties lining the tank. We'll see where this leads us. He said he's gonna look and see if he can find a replacement tank and if that doesn't work, try again with the one I brought in.
Old 05-17-2011, 02:23 AM   #8
52merc
52merc's Avatar
i used redkote liner i left the tank for a year and same happened to me,i looked at their web site and they said there has been very small amount of gas turning red this they put down to aditives,i sent my tank out they had it for 8 dam weeks and couldnt get the liner right out so i cut a hole in the tank took it to sandblaster who removed it asll,i relined with the liner no problems yet,,i hear that por15 has a PROVEN RECORD WITH THERE LINER TREV HAVE FUN
52merc is offline   Reply With Quote
