Old 11-13-2023, 11:46 AM   #1
sjaakslinger
sjaakslinger's Avatar
Default Worn crankshaft pulley
Working on a 36 LB engine. The crankshaft pulley is worn. See pics. What are my options here?
Replacement pulley? Get one of those sleeves and modern seal? Anyone experience with the latter?
Thanks.
Dennis
Verstuurd vanaf mijn SM-G781B met Tapatalk
sjaakslinger is offline   Reply With Quote
Old 11-13-2023, 01:32 PM   #2
tom1948
Default Re: Worn crankshaft pulley
I have used the sleeves and seal with varying success. I personally would buy a new pulley.
tom1948 is offline   Reply With Quote
Old 11-13-2023, 02:29 PM   #3
51woodie
51woodie's Avatar
I have used SKF speedi-sleeves in everything from small engines to big industrial equipment, and have always had success. The important thing is, to follow the instructions.
https://www.skf.com/ca/en/industries...-speedi-sleeve
51woodie is online now   Reply With Quote
Old 11-13-2023, 03:32 PM   #4
FlatheadTed
FlatheadTed's Avatar
I would just turn that off in a lath fit a speedy sleeve or make sure the rope seal sits proud and tight on it ,
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 11-14-2023, 07:50 AM   #5
Terry,OH
Terry,OH's Avatar
That area was not originally smooth and flat. It had a screw thread pattern. Oil in this area would enter the screw thread and the rotation of the crank would return the oil to the oil pan. NOS pulleys are getting hard to find.
Old 11-14-2023, 09:34 AM   #6
sjaakslinger
Yeah, the flathead rebuild book brought me to this issue. I see some mixed ideas here on the sleeve or new pulley.
Just wonderung what's better. Sleeve and seal are relatively cheap and new pulley indeed hard to find.
Dennis
Old 11-14-2023, 10:05 PM   #7
cmbrucew
cmbrucew's Avatar
Pulleys can be brazed to repair the seal surface or repair a break. Pre heat in the barby and use it to cool down after. Lathe finish to specs. Shipping from the US would be expensive.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
