Old 03-07-2024, 10:31 AM   #1
Zax40
Zax40's Avatar
Default Replace rear motor mounts
Is it possible to change the rear motor mounts one at a time with the motor in the car and no frame spreader?
Zax40 is offline   Reply With Quote
Old 03-07-2024, 10:45 AM   #2
Bruce of MN
Bruce of MN's Avatar
Default Re: Replace rear motor mounts
It is a toss up. When I reinstalled my engine in 2020, I didn’t need a spreader.
Old 03-07-2024, 10:55 AM   #3
Phil Brown
Phil Brown's Avatar
Can it be done.......sure, but I don't think that you'll ever want to do it that way again.
Phil Brown is offline   Reply With Quote
Old 03-07-2024, 11:34 AM   #4
Will N
Will N's Avatar
I've done it. Lots of lube and mallets.
Will N is offline   Reply With Quote
Old 03-07-2024, 11:48 AM   #5
J Franklin
J Franklin's Avatar
A small bottle jack and 2X4 is all that is needed to spread the frame enough to do the job easily.
Old 03-07-2024, 01:04 PM   #6
Bob Bidonde
Bob Bidonde's Avatar
I have changed the rear engine mounts in my A's a few times, and it was not necessary to spread the frame.
I did a comparison between an original set of Engine Rear Support Cushions A-5092 Inner and A-5094 Outer that were made by Firestone. The Firestone cushions were laminated rubber with a one ply cloth inner layer. The original Firestone cushions are thinner than the rubber reproductions. So I abrade some rubber off of the thickness of the inner reproduction cushions, about 1/16" to 3/32".
You can see the original Firestone Cushions on Vince Falter's Ford Garage https://www.fordgarage.com/pages/aen...rtcushions.htm
Bob Bidonde
Old 03-07-2024, 01:33 PM   #7
Zax40
Zax40's Avatar
That is good to know. I have several bottle jacks and pieces of 2x4 in my garage. But I don't own a frame spreader.
Old 03-07-2024, 02:08 PM   #8
alexiskai
alexiskai's Avatar
What are the two points you’re using to brace against?
Old 03-07-2024, 05:17 PM   #9
J Franklin
J Franklin's Avatar
The frame rails.
Old 03-07-2024, 05:18 PM   #10
J Franklin
J Franklin's Avatar
The frame rails. I---I
