Old 06-03-2022, 07:19 PM   #1
tubman
tubman's Avatar
Default Double posts
There have been a bunch of double posts lately. When I have posted a response, I am experiencing a long delay between hitting the "POST" button and it actually appearing. Just now, I received a "double post" warning when I knew I hit the "POST" button once. Response on the server seems to be quite degraded; someone should check for a virus or other problem.
Edit : It took almost 30 seconds for this post to be made. Much longer than usual.
Old 06-03-2022, 07:23 PM   #2
Bob C
Default Re: Double posts
I've notice the same thing, it's on the Model A board also.
Old 06-03-2022, 07:26 PM   #3
VeryTangled
VeryTangled's Avatar
Hi tubman, good report.
There are hundreds of possibilities for internet congestion.
Here's something folks should give a lookey-loo. I just found the router at Mom's place was wanting an update and doing that revved her up like dropping in a new engine.
A suggestion of you want an Admin to see your message quickly is to report your own posting.
Adding: This reply also took a while to post. The software also inserted double carriage returns. Something does seem jacked up.
-Jeff H
Old 06-03-2022, 07:53 PM   #4
tubman
tubman's Avatar
Done.
Old 06-03-2022, 07:55 PM   #5
Ryan
Administrator
Ryan's Avatar
Ok fellas. I will work on this over the weekend. Sorry for the hassle.
Ryan Cochran*
- www.AtomicIndustry.com
Ryan is offline   Reply With Quote
Old 06-03-2022, 09:22 PM   #6
GB SISSON
GB SISSON's Avatar
Thank you Ryan, I have been experiencing this as well.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 06-04-2022, 04:16 AM   #7
Mart
Mart's Avatar
Thanks Ryan.
We appreciate the effort you put to keep the barn idling over sweet.
Old 06-04-2022, 01:57 PM   #8
Ryan
Administrator
Ryan's Avatar
OK fellas... Should be fixed now... Turns out tapatalk was trying to skim data from our posts. They were unable too obviously, but it was responsible for the slow down. I've removed support for Tapatalk.
Ryan Cochran*
Old 06-04-2022, 05:39 PM   #9
scicala
scicala's Avatar
Thank you Ryan !
Sal
scicala is offline   Reply With Quote
Old 06-05-2022, 10:00 PM   #10
Tinker
Tinker's Avatar
Glitch in the matrix.
When everything works well nobody knows what is being done behind all of it. I'm surprised everything works as well as it does with only a little bump. For sure, much appreciation to the team that makes it happen!
