03-20-2018, 01:10 AM | #21 | |
Re: PCV systems on the smallblocks
Yeah it did come to think of it. THANX for the memory jog...
***** We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ... |
03-26-2018, 04:48 PM | #22 |
You can't really see the pcv, it is off the 2 big vac ports and Teed. 5.0 efi intake modified to use twin .98 2100s on my 260.
03-30-2018, 10:34 AM | #23 |
It wasn't the best system in cold climates. There was a mesh screen under it and short drives in sub zero would freeze it into a block of ice. Blowby would start oil leaking from all the gaskets and seals.
04-08-2018, 11:08 AM | #24 | |
Finally got the cartridges but FIREFOX updated my browser and I cannot communicate with the printer. As soon as I join the living again, I will show the drawing. ADDENDUM- SHELBY COBRA TIGER
***** We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ... Last edited by KULTULZ; 04-08-2018 at 08:33 PM. Reason: ADD EYE CANDY |
04-11-2018, 02:36 AM | #25 |
Finally...
The setup is for both 2V and 4V.
04-11-2018, 07:15 AM | #26 |
04-11-2018, 08:32 AM | #27 |
Yeah, that is the actual oil/vapor separator and is necessary. It is replaced on a scheduled basis.
C2OZ 6A631-A - FA-58 Gasket PN- C2OZ 6870-A (FEL-PRO should have it) Valve PN- C1AZ 6A666-A
11-27-2020, 12:59 AM | #28 |
Road draft was absolutely used in the 1965 model year. Absolutely.
Pete's Ponies Mustang RUSToration & Performance |
11-27-2020, 09:09 PM | #29 |
When and if this all goes togather I have a 66 4 bbl intake that has the provision and the three threaded holes for that PCV system but the larger hole is not drilled so it will have to be machined.
11-27-2020, 11:15 PM | #30 |
They were delivered different ways. Some had a plug in the hole. Some had nothing but a flat place where it went. Some had the threaded holes for fasteners, but no opening for the gases.
11-28-2020, 08:19 AM | #31 | |
Now for the earlier road draft design. Two SBF tubes shown below, one manifold mount and the other rocker cover mount (1965) -
11-28-2020, 11:25 AM | #32 |
Yep, correct
11-28-2020, 02:19 PM | #33 |
The PCV on the EFI is a pain to get to.
