Old 08-29-2014, 06:17 PM   #1
Ian in Mississauga
Default PLugged exhaust
I think some critters have built a nest in my exhaust pipe. Anyone have some advice on clearing the blockage?
TIA IAn
Ian in Mississauga is offline   Reply With Quote
Old 08-29-2014, 06:22 PM   #2
Mitch//pa
Default Re: PLugged exhaust
try to start it up and floor it. i shot one across the room out of a modern car like a bullet. after landing it was walking around in circles.
Old 08-29-2014, 08:07 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Try Mitch's idea first and if that doesn't work then remove the muffler, pour some gas down the pipe and carefully light it to burn the nest to ashes, which should blow out. You may want to connect the exhaust of the shop vac to the pipe to make the fire burn better.
