06-27-2017, 05:23 PM | #1 |
Torque tube location
Putting my 34 together and seems to be a lot of front to rear travel in the clam shell .
I am just fitting things now but I can't believe that the front joint has anything to do with the play Or is the front mount which is old the problem Any help would be awesome Thanks I forgot it's a V8 5 window coupe Sent from my iPhone using Tapatalk |
06-27-2017, 05:26 PM | #2 |
Re: Torque tube location
4 cyl or V8??
Paul in CT |
06-27-2017, 05:27 PM | #3 |
06-27-2017, 05:28 PM | #4 |
Did you install the inner cap??
Bob |
06-27-2017, 05:41 PM | #5 |
In my limited experience, there should be no play there. That connection should be firm (but free) front to back, up and down and side to side.
35 Ford Cabriolet 56 Chevy Pickup 63 VW Bug Empty wallet |
06-27-2017, 05:48 PM | #6 |
06-27-2017, 05:50 PM | #7 |
06-27-2017, 05:51 PM | #8 |
Then what is the cup on the torque tube mounted against?
06-27-2017, 05:53 PM | #9 |
06-27-2017, 05:58 PM | #10 |
The Green Book is your friend! Another good source is VanPelt http://www.vanpeltsales.com/FH_web/F...nd-32-48-A.jpg
06-27-2017, 06:02 PM | #11 | |
Well that's awesome Now I just have to find someone with the part for sale Thanks Sent from my iPhone using Tapatalk |
06-27-2017, 06:08 PM | #12 |
There should be U-joint caps available but there are used ones out there too. A copy of the 1928 through 1948 Ford Chassis Parts Catalog (aka the green bible) is a good thing to have and the ones on CD/DVD are not too bad a price.
06-27-2017, 06:14 PM | #13 | |
Will do thanks Sent from my iPhone using Tapatalk |
06-27-2017, 06:37 PM | #14 |
Or free is an even better price if you want to download them from the Ford V8 club site. The DVDs are a good deal though because of all the additional data that is included, something like 10 different parts books total I think. Looking at the label it may be 13, have to check.
06-27-2017, 06:53 PM | #15 | |
06-28-2017, 07:14 AM | #16 |
A good source for parts like this is Fred Wilner at Southside obsolete. Order by phone. http://www.southsideobsolete.com/Sou...e/Welcome.html
Also is" barn find" here on the forum John |
06-28-2017, 07:49 AM | #17 |
I was going to add barnfind08, but see John already added that note!
06-28-2017, 09:39 AM | #18 |
Vanpelts catalog shows the part you are looking for, B-4513 available for $20.00. Be sure and get a copy of his 62 page catalog.
06-28-2017, 01:44 PM | #19 |
And don't forget the cork or felt seal in the back of the 'clam shell' as its absence will lead to a mess of grease for the u-joint leaking and also add to the fore and aft free play.
