02-22-2013, 01:11 AM | #1 |
French Flathead No Distributor whats available?
Hi I have a French Flathead without a Distributor .Not much chance of finding a Loadamatic and I dont hear they are to good anyway . Whats available to go on one of these,? approx Price?
If I change the front plate Will an early distributor fit if off a 24 stud or 21 stud engine? Any other parts required ? Thanks for any help John Cochran |
02-22-2013, 01:36 AM | #2 |
Re: French Flathead No Distributor whats available?
get a sbc from bubbas
02-22-2013, 04:28 AM | #3 |
John, as stated above, SBC distributors can be adapted quite successfully. The French dist is a vacuum only unit like a loadamatic. Bit crap really. (I have one but the vac unit does not work so not a lot of good really). A front mount dist can be used (I have done this) if you switch to a 59a type cam, two bolt front cover and a crab dist. Divers helmet type could also be used with the right cover, but imho the crab is the easiest to get working right.
Mart. |
02-22-2013, 06:45 AM | #4 |
as you live in france you could find this easily . Last time a friend find one new in box for 100€ to chateauroux swap meet .
02-22-2013, 08:17 AM | #5 |
No need to change anything. We build a direct replacement using a drawing off the orginal using a chevrolet housing.
Cost is $180 with contact points. |
02-22-2013, 09:02 AM | #6 |
02-22-2013, 09:22 AM | #7 |
I can also attest to Bubbas work. My Flathead runs great!
02-22-2013, 09:40 AM | #8 |
John,
I have an orignal French distributor from a French Block at home. If you want it sent me a PM. I'm living in Germany |
02-22-2013, 03:35 PM | #9 |
Thanks to all who replied, Looks like Bubba's Distributor sounds like favorite
John Cochran |
02-23-2013, 01:59 AM | #10 | |
Bob I must have just missed that Distributor I have been to that Swap for the last 5 years!!!One of the best I have been to in France , Though I imagine the one's in the North might be better . Have you posted pictures of your 32 Tudor on here yet? I am sure that lot's of people on here would like to see it .The European Tudors were a lbit different than the USA versions. John Cochran |
02-23-2013, 03:39 AM | #11 | |
