Old 07-10-2020, 11:32 AM   #21
A bones
A bones's Avatar
Default Re: paint on oil pan?
Thank you, I thought Duntovs were earlier.
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
Old 07-10-2020, 01:22 PM   #22
V8COOPMAN
V8COOPMAN's Avatar
Without going back and looking it up, I believe you're actually correct. I believe the Duntovs were peddling the Arduns in the LATE '40s, and of course, the first PRODUCTION hemi was '51.....RELATIVELY close. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 07-10-2020, 01:53 PM   #23
grumppyoldman
grumppyoldman's Avatar
Originally Posted by Joe Immler View Post
grumpy, will it work to paint the inside of a starter and generator?
Yes it works in starters and generators also, but not on the armerture or coil areas. Al
grumppyoldman is offline   Reply With Quote
Old 07-17-2020, 01:07 AM   #24
Blownflatheaddeuce
Blownflatheaddeuce's Avatar
I like clean, clean is good.
Never an issue !
Blownflatheaddeuce is offline   Reply With Quote
Old 07-17-2020, 08:41 AM   #25
Bored&Stroked
Bored&Stroked's Avatar
Moved to the main thread . . .
Old 07-17-2020, 10:20 AM   #26
philipswanson
I hope you didn't blast the inside of your pan. If you did, get another.
philipswanson is offline   Reply With Quote
Old 07-17-2020, 10:55 AM   #27
Blownflatheaddeuce
Nope, hot tanked
Old 07-17-2020, 02:35 PM   #28
JSeery
JSeery's Avatar
Never an issue !
I like it!
Old 07-17-2020, 05:41 PM   #29
5851a
I've never painted the inside of an engine myself. If bare steel and iron lasted 70 years or so I didn't think I could improve. None of the older hi performance engines were painted inside. Ford was doing some E coated pans on engines in the 80's and have heard that some of it came off and plugged the oil pump pickup screens.
5851a is offline   Reply With Quote
Old 07-18-2020, 02:43 PM   #30
ct1932ford
ct1932ford's Avatar
This is an interesting thread for sure. Before reading it I would have said absolutely not. Now I'm not sure. I will keep watching the debate.
A man should do what he thinks best! "The Duke"
ct1932ford is offline   Reply With Quote
Old 07-18-2020, 04:10 PM   #31
Pete
Pete's Avatar
Originally Posted by JSeery View Post
I always paint the inside of the blocks. One of the reasons is it increases the rate of oil return to the oil pan.
Many people use paint or glyptal for that reason.
On a wet sump engine it probably wouldn't show any gain on the dyno.
On a dry sump engine that runs 20 inches of vacuum in the pan, polishing all surfaces in the crankcase and valve areas will show 4 to 5 hp gain from reduced windage and better scavenging of the oil.
Using paint or glyptal might offer some advantage but you would still have the rough surface.
Old 07-18-2020, 04:15 PM   #32
JSeery
JSeery's Avatar
I do polish down the rough surfaces. I assume there is not any major advantage to it, just what we did the in 60s and I have kept doing it.
Old 07-19-2020, 09:42 AM   #33
rotorwrench
rotorwrench's Avatar
This is a question with two answers. Either do it or don't. If a person has a hobby car and runs it often, there is nothing wrong with leaving it the way it came from the factory. If you want to then do it. Most folks use it to seal castings for better run off of lubricant. On a smooth stamped steel surface, the motor oil will preserve it as long as the vehicle is used on a regular basis.
Painting something doesn't always guarantee that it won't corrode. If corrosion starts between the paint and the subsurface the the paint will start to flake off. If it is painted then it's a good idea to clean the surface well and use a conversion coating to passivate it.
