Old 11-11-2017, 04:12 PM   #1
MickeyT
Send a message via MSN to MickeyT Send a message via Yahoo to MickeyT
Default OK.... Newby dumb question
'31 CCPU. If only the passage side door handle had a key lock how did the drivers side door get locked?
MickeyT is offline   Reply With Quote
Old 11-11-2017, 04:18 PM   #2
mike657894
mike657894's Avatar
Default Re: OK.... Newby dumb question
it should have a lock swtich in the upper back corner. i have 1 key lock and 3 switch locks on my fordor
mike657894 is offline   Reply With Quote
Old 11-11-2017, 04:22 PM   #3
MickeyT
Oops, no switch. Any chance someone has a picture?
Old 11-11-2017, 04:34 PM   #4
slammin
slammin's Avatar
Welcome to the Barn and the wonderful world of model As. Drivers door had to be locked from the inside. Then you scooted across the passenger seat to exit, locking the door with the key. This was done for safety. I guess some weren't smart enough to hop out without looking for on coming traffic. I understand that some states still have traffic laws prohibiting exiting a car from the drivers side. If no one posts a picture, check out some of the model A dealers , looking for an interior shot of the drivers door. Several of the Model A vendors sell a repro door lock. Since I'm not building a fine points show car, I will replace my plain door handle with one that locks.
slammin is offline   Reply With Quote
Old 11-11-2017, 04:42 PM   #5
1930-Pickup
Late 1930 CCPU
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!"
1930-Pickup is offline   Reply With Quote
Old 11-11-2017, 04:48 PM   #6
MickeyT
That is great. Thanks for the picture. I've found the parts and am putting them on order.
Old 11-11-2017, 04:52 PM   #7
msbrown6
msbrown6's Avatar
Just FYI Mickey - no such thing as a dumb question in these forums. Jump on in!
msbrown6 is offline   Reply With Quote
Old 11-11-2017, 04:54 PM   #8
1930-Pickup
Glad to hear it.
Welcome to the Barn!
Old 11-11-2017, 05:10 PM   #9
michael a
michael a's Avatar
Originally Posted by 1930-Pickup View Post
Glad to hear it.
What's a dumb question
Sent from my SM-J700T using Tapatalk
michael a is offline   Reply With Quote
Old 11-11-2017, 05:58 PM   #10
Tom Wesenberg
Tom Wesenberg's Avatar
When you have the door panel off, be sure to lube all the moving parts and replace any broken springs. My doors work great since I replaced the bad springs in the latch and greased everything. I still need to replace the spring in the center of the rod from the handle to the latch assembly.
Old 11-11-2017, 07:06 PM   #11
MickeyT
I tell you I've had the panel off a couple of time must have completely missed the spot where the lock goes. I cleaned and lubed (without removing) most all of the door components and did not see any lock.
Old 11-11-2017, 08:16 PM   #12
1930-Pickup
When I got my truck the lock knob and shaft were bent over and covered with an ancient and disgusting white vinyl door panel. I straightened the shaft and cleaned the knob...works great
Old 11-12-2017, 12:38 AM   #13
SSsssteamer
SSsssteamer's Avatar
How to lock your model A doors: When the wife and I go for a ride where our model A doors get locked, I lock my drivers door from the inside as am I getting out. Then I walk around to the passenger door, and after the wife gets out, I lock her door handle with my door key. After returning to the model A, I first unlock her door handle with my key so she can get in and unlock my driver's door handle from the inside. Not a problem at all, and it is nice having a secure vehicle.
SSsssteamer is offline   Reply With Quote
Old 11-12-2017, 03:22 AM   #14
Mike V. Florida
Mike V. Florida's Avatar
Originally Posted by msbrown6 View Post
just fyi mickey - no such thing as a dumb question in these forums. Jump on in!
..x2
Old 11-12-2017, 05:03 AM   #15
john charlton
john charlton's Avatar
You could have a RHD left door .In RHD vehicles the key locking door is the left door the left door is not set up to take the interior sliding lock no "D" nuts . The right door has the sliding lock .
John in crisp cold sunny morning Suffolk County England .
john charlton is offline   Reply With Quote
Old 11-15-2017, 08:24 PM   #16
Ronald
Ronald's Avatar
And remember that the gear shift lever moves upwards toward the dash to allow the driver to slide across the seat to the passenger side and exit .
Ronald is offline   Reply With Quote
