07-25-2015, 03:38 PM | #1 |
Starter Jammed on ring gear
Got my starter Jammed on the ring gear in the Pickup . I guess the 12 Volts I have been putting thru it is trying to pull the ring gear off !!!
Engine locked up tight, I Have removed bolts on starter but can't move that either!!! any Tips???? to free it off Thanks in advance John Cochran |
07-25-2015, 03:43 PM | #2 |
Re: Starter Jammed on ring gear
07-25-2015, 06:26 PM | #3 | |
07-25-2015, 09:51 PM | #4 |
A friend got stalled on his restoration for 5 years, because of a HORRIBLY locked up starter.
I went over with my long 1" cement breaking bar, aimed, hit the starter case @ about 2 o'clock position & it fell out on the second hit. Sometimes, BRUTE force is necessary!!! I tole you I wuz GOOD!!--LOL---Brush the flywheel teeth with HEAVY wheel bearing grease & rarely will lock up happen again!!! Bill W.
07-25-2015, 10:24 PM | #5 |
Same thing happened t me. Hit the starter with a BIG rubber mallet and it fell off.
07-26-2015, 11:55 AM | #6 |
The Bigger Hammer with a 2x3 and some pushing back and forth did the Trick !!!! Have also put some old Black Grease on there as Bill W recommended All Working Good Now !! |
07-26-2015, 01:30 PM | #7 | |
I learned the GREASE trick while working on Jaguars & the Rootes' Group cars, the starter drives were the same design as The Model A's. Rockys' "EVIL TWINS"--A vintage dragster, has the side by side engines "hooked" together through the flywheel TEETH!! Just grease teeth & you're OFF, singing a FINE TUNE Bill W.
10-06-2015, 05:01 PM | #8 |
We'll Bill, I am 600 miles from home and have had starter lock up problems and yesterday broke the bolt on the starter drive. I repaired the drive and added the heavy black grease to the gear. So far so good. Thanks for the tip. JB
10-06-2015, 08:39 PM | #9 | |
Bill W.
"THE ASSISTANT GURU OF STUFF" Last edited by BILL WILLIAMSON; 10-07-2015 at 10:12 AM. |
