Old 08-28-2014, 04:50 PM   #41
hardtimes
hardtimes's Avatar
Default Re: Babbitt and Shim Question
Originally Posted by juke joint johnny View Post
Well Hardtimes Looks like we Rattled a few Cages on this one !!! 5 Star Thresd as Well
I'm worried Folks will be out with their Shootin Irons if it carries on.!!!
Just to set the Record Straight and to lighten things up
Are Wonder Womans Bracelets Steel or Brass or did you even notice she had Bracelets?!!
John Cochran
Lasso/Bracelets....where !
Hey John,
Very interesting is your inquiry. Maybe since you are involved in informing the engine builder just ...what Americans say, you could let us know whether he decided to use (farmer) shims or no Hm, wonder if he ever heard of Henry?
hardtimes is offline   Reply With Quote
Old 08-28-2014, 04:51 PM   #42
hardtimes
hardtimes's Avatar
Originally Posted by Tom Wesenberg View Post
I think we may need to call in Wonder Woman with her trueth lasso.
Hey Tom,
You are a funny guy...with CLASS, A..eh !!
Shouldn't even ask what she looks like today...huh
Old 08-28-2014, 05:00 PM   #43
Tom Wesenberg
Tom Wesenberg's Avatar
Originally Posted by hardtimes View Post
Hey Tom,
I saw Lynda Carter on TV a few days ago, and she is still very beautiful.
Her bracelets must be krypton to deflect the bullets.
Old 08-28-2014, 05:35 PM   #44
zzlegend
zzlegend's Avatar
Hope the bullets aren't made of steel. They might magnetize to her bracelets.
zzlegend is offline   Reply With Quote
Old 08-31-2014, 02:52 PM   #45
hardtimes
hardtimes's Avatar
Originally Posted by forever4 View Post
See Ford Babbitt and Shims on Ford Garage for more on steel shims.
Hey forever4,
Thanks Vince , once again, for your great site into !
This time focused on types of shims , proper shimming and shimming vs no shimming informtion
Put a smile right on my wrinkley face , as I've been ...reading and applying and sometimes that can be dangerous/costly ! In this case, I've followed some advice from other old timers , who essentially have said what you have written. Consequently, I now have a full pressure B short block with poured Babbitt without main/rod shims ! First time read of your writings here, re shims, adds confidence that such will be good !
However, I've got to wondering at what RPM did Ford drive dry short blocks with electricity ! When breaking in , 1200 rpms for X minutes is recommended. Do you have any idea what rpm, elect motor drove these engines ?
Wonder if anyone here has ever tried to do as Ford did to break in their short block And, what HP motor do you suppose it would take to do the job ?
I'm guessing my used wash machine motor wouldn't do, eh !!
Old 08-31-2014, 03:02 PM   #46
Mike V. Florida
Mike V. Florida's Avatar
I read that they ran the engines while looking at the current draw of the electric motor. The stiffer the engine the more current it would draw. One the current when down to a certain amount the engine was loose enough. At least that is what I read. Sounds good but I have no Ford documentation to confirm it.
Old 08-31-2014, 03:10 PM   #47
darrylkmc
darrylkmc's Avatar
Wonder if anyone here has ever tried to do as Ford did to break in their short block !
All of the photos that I have seen were Fully Assembled engines and not Short Blocks.
Frosted here the last 2 nights, could be coming to a town near you soon.
Darryl in Fairbanks
darrylkmc is offline   Reply With Quote
Old 08-31-2014, 07:41 PM   #48
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Hey forever4,
A couple of things to think about. The crankshaft was burnished early in the assembly process with a different type rotating machine, so that was a different process than what most people think of when they look at the pics of the row of dynamos with the assembled engines mounted on them.
FWIW, I have shown that picture to several electrical engineers asking why the motor was so large, and I have been told these would likely be very low-speed, hi-torque electric motors. Therefore I would suspect the RPM to be well under 60 RPM. I also suspect the engines were not spun long on the dynamo as I see no evidence the pan nor the transmission had any oil added during that process. The reason I feel water was added during this process was to check for leaks due to porosity in the castings/gaskets/etc.
As for the need to run-in, I think there are two key factors in saying No need. First, Ford used quality machines during the boring & honing process which ensured the cylinder case walls were as true as necessary for a good seal. Second, consumers back in the day understood the "break-in" process for a new vehicle, and since they accepted this process, then there was not a need to break-in a new engine at the factory. As for today, those of us who have good quality professional machines to do the engine machining processes find our rebuilt engines "sealing up" within minutes of the initial start-up.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 08-31-2014, 08:56 PM   #49
hardtimes
hardtimes's Avatar
Darryl in Fairbanks
Hey darryl,
Frosted...ahhh, I can only dream ! 110 in the shade here ! At times 115 in my tiny work shed. Why even the four polish bars MELTED when set in direct sunlight for a short time. Picked up the container, and ha..noticed that it sagged a bit. Pocked with finger and all four bars were liguid..who knew that that could happen !
Several years ago I drove up and stayed 2 months in your beautiful state. Always said coming back you to stay 4 months..leaving sometime in Sept, as that's when we've determined that the snow/freezing storms can make first appearance.
Anyway, yeah I've seen the HUGE motors that are in the same pics as the ford engines. And, the engines did appear somewhat complete. However, the engine still had to be broke in/burnished bearings..whatever it was named. Here's another question, (in my mind,eh ). When turning those engines over,i.e.- metal/metal..no lube (?), was that a very short (breakin) event or how could the heat be handled..to prevent galling/scoring, without coolant. I did not see anything that looked to be water hose ?
Finally, Vince says that TERMS used to describe lifters are confusing.
What confuses me, personally, is that a lot of smart guys here use the term motor ...when talking clearly about an engine Splain that to me please
Old 08-31-2014, 09:10 PM   #50
BRENT in 10-uh-C
If you would read all the posts, you would see this is addressed. The bearings were NOT being burnished with the dynamos where the engines are completed and have the transmissions mounted. Also look at the pictures of the assembled dynamo and you will see the cylinder case is filled with coolant through the inlet port. The coolant was not circulated, therefore no need for an outlet connection.
As far as engines vs. motors, some people use Ford nomenclature to avoid confusion. The term Motors was the standard back during the Model-A era.
BRENT in 10-uh-C
Old 08-31-2014, 10:02 PM   #51
Purdy Swoft
Purdy Swoft's Avatar
Hey darryl,
I've been told that the term MOTOR describes an electric motor. Engine would be used to describe a piston engine.
Old 08-31-2014, 11:54 PM   #52
bbrocksr
FWIW, I have shown that picture to several electrical engineers asking why the motor was so large, and I have been told these would likely be very low-speed, hi-torque engines. Therefore I would suspect the RPM to be well under 60 RPM. I also suspect the engines were not spun long on the dynamo as I see no evidence the pan nor the transmission had any oil added during that process. The reason I feel water was added during this process was to check for leaks due to porosity in the castings/gaskets/etc.
Brent, You were told that these were low speed high torque "engines" by several electrical engineers ?
Bill
bbrocksr is offline   Reply With Quote
Old 09-01-2014, 12:23 AM   #53
BRENT in 10-uh-C
Bill
Good catch! I'll go back and change that! Thanks!!
BRENT in 10-uh-C
Old 09-09-2014, 10:42 PM   #54
5window
5window's Avatar
Typically, we'd only call it an electric "motor" while an internal combustion engine-is also frequently referred to as a motor. The reality is that the situation is much more complicated and the words are, at least technically, pretty inter-related.
http://engineering.mit.edu/ask/what%...tor-and-engine
5window is offline   Reply With Quote
Old 09-09-2014, 10:45 PM   #55
5window
5window's Avatar
No need to change-the "engineers" are technically correct: "The Oxford English Dictionary defines “motor” as a machine that supplies motive power for a vehicle or other device with moving parts. Similarly, it tells us that an engine is a machine with moving parts that converts power into motion." See the reference in my other post
Old 09-09-2014, 11:12 PM   #56
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Talking Re: Babbitt and Shim Question
Piece of useless information : that's how milkshake machines( at least 50 years ago) controlled the thickness of the mix. Maybe they borrowed the idea from Ford?
Thread Tools
Display Modes
