Old 12-17-2020, 02:35 PM   #1
hotrodman222
Default Flathead crank pulley questions
I have searched through all the pulley threads and maybe I gave up too soon.
So the issue is I have a 34 ford with a 1949 flathead running a crab style distributor and truck water pumps and it works great. I am building a new engine and I want use the same set up, but I can't find a crankshaft pulley that works. Obviously the guy that I bought the 34 from had a custom pulley made.
Who makes a custom crankshaft pulley? Or is there a Ford pulley that uses that will work? Thanks.
hotrodman222 is offline   Reply With Quote
Old 12-17-2020, 02:40 PM   #2
skidmarks
skidmarks's Avatar
Default Re: Flathead crank pulley questions
Truck water pumps with wide belts?
Is the stock 8BA stamped steel pulley too large in diameter to work with the crab cap distributor?
skidmarks is offline   Reply With Quote
Old 12-17-2020, 03:13 PM   #3
hotrodman222
Yes it is. The diameter is 5 3/8 or so and I need about 5 inch max.
Old 12-17-2020, 03:34 PM   #4
Tony, NY
I have a crab on my '51 Merc engine. I dug up a photo from 10-15 yrs ago. I machined the OD of the pulley to clear. It wasn't a stamped pulley.
Tony, NY is offline   Reply With Quote
Old 12-17-2020, 06:01 PM   #5
hotrodman222
What diameter did you machine it?
Old 12-17-2020, 07:33 PM   #6
Tony, NY
I can't say off hand. From what I remember it was just enough to clear the distributor. I can try to get a measurement tomorrow. I think there was a raised area on the pulley that I machined off.
Old 12-17-2020, 08:33 PM   #7
hotrodman222
Thanks
Old 12-18-2020, 02:25 PM   #8
Tony, NY
This is the type of pulley I started with ( crazy price). The front pulley is approx. 5 3/8 inches dia. My machined pulley area is a little larger around 5 1/2". https://www.ebay.com/itm/1949-50-51-...wAAOxyxpxQ7475
