09-08-2017, 10:47 AM | #1 |
1935 big truck bench seat question
Hello friends and thanks for looking at my thread: a customer brought me a project and one of them involves the installation of a bench seat over the gas tank. The wooden part of the bench is MIA but that isn't my issue as much as this question: did the '35 big truck have a full bench or just a half seat? I made a plywood template and it looks as if the fill neck interferes with the passenger side of the seat. Does anyone have a picture of where these two parts come together? I appreciate any assistance in this and thank you.
09-08-2017, 11:29 AM | #2 |
Re: 1935 big truck bench seat question
The seat should be the same as the pickup -- the top is covered springs with two hinges that attach to the wood base and cushion. The metal platform that the wood base sits on should have a protruding post in each of the front corners. This is where the seat "adjustment" is -- a rectangle piece of metal with 3 holes in it for the "adjustment". If i could attach a photo, I would.
09-08-2017, 11:40 AM | #3 | |
Hi - thanks for the reply. I get that part ok. The problem I am experiencing is that I am having interference with the gas tank fill neck. The "metal platform" is the gas tank itself with 2 protrusions for the adjustment. I have also just realized the photo is sideways - thanks iPhone. Please rotate that in your mind 90° counter clockwise.
09-08-2017, 11:43 AM | #4 |
Here are a few pictures. Note the three holes on each side as pointed out by nelsb01.
09-08-2017, 11:46 AM | #5 |
One more picture. Both sides are the same.
09-08-2017, 11:52 AM | #6 |
09-08-2017, 11:56 AM | #7 |
Then again when I look under the truck it is clear the tank is designed to be there so maybe I have the wrong bench? This is confusing when you're asked to complete what someone else started.
09-08-2017, 12:43 PM | #8 |
Bones, The seat cushion should sit on top of the gas tank. As others have pointed out, the tank has metal pins(dowels) on each front corner. The wooden frame has 3 holes on each front side. By moving from one set of holes to the other, you adjust the seat cushion.
09-08-2017, 12:59 PM | #9 |
Thanks Don - so you have a full bench on that tank? The folks at Early Ford V8 Sales thought I should have a split bench. The bench I have (not oem btw and missing the wood part) is definitely too wide for the tank - it interferes with the fill neck. Do you have a pic of the bench on the tank? That would answer a couple of questions for me. Thanks!
09-08-2017, 04:06 PM | #10 |
Bones, Here are some images from Ford promotional films showing the seat on the tank. Further checking indicates that the seat cushion ass'y (51-815350) is not the same as the pickup truck. I'll keep looking for mare info.
10-31-2017, 07:23 PM | #11 |
Did you ever resolve your questions? I was contacted by Don on this topic and just found this thread. I'm restoring a 1935 big truck and have lots of information and original seat parts which should answer all of your questions. The big truck and pickup seats are different. I have an original and pattern and Ford parts drawing for these items. Let me know if you still need information.
Dave |
11-28-2017, 09:15 AM | #12 |
Dave, I would love more information. I sent you a PM. Thanks for any help you can give.
