Old 06-05-2017, 05:55 PM   #1
Gerryde
Default 1928-29 roadster pickup interior wood work
Hi folks,Iam in the process of doing the wood work on my 28/9 roadster pickup.its the woodwork for the scuttle around the side panels and the back panel .If anyone can help it would be very much appreciated.thankyou.
Cheers Gerry.(NZ)
Gerryde is offline   Reply With Quote
Old 06-05-2017, 06:51 PM   #2
Russ/40
Russ/40's Avatar
Default Re: 1928-29 roadster pickup interior wood work
What is it you need to know?
Old 06-05-2017, 07:22 PM   #3
Gerryde
Hi Russ at the moment i have done all the side panels and the panel at the back. its the wood work that goes in on the side panels and the wood work that goes in on the back panel.The seat fram is sitting in there as well . Cheers Gerry(NZ)
Old 06-05-2017, 09:10 PM   #4
Russ/40
Russ/40's Avatar
I have everything in photos that I can send you. Give me an email address and I'll send them to you.
respond to: [email protected]
Old 06-06-2017, 05:27 PM   #5
Mad Mac
No woodwork around the scuttle/cowl, only the side quarter-panels and the rear panel and even there not very much. They are not hard to make if you know what they look like. Someone will have pics.
Mad Mac is offline   Reply With Quote
