05-20-2015, 08:09 PM | #1 |
1937 Ford Clutch Install
I will be installing a new clutch on my 1937 Ford De Luxe 85hp. I will be pulling the rear end off and dropping the trans to make the install. I have never installed a clutch before. I have a knowledgeable helper coming by to give me a hand. To save time I will have most of the preparation done before he gets here (removing the seat, floor, drain trans, etc).
Do I need any special tools to pull off the throw-out bearing and the pilot bearing? Any tips or advice for this install greatly appreciated. Please help. Thank you Members of Ford Barn. TonyM. |
05-20-2015, 09:05 PM | #2 |
Re: 1937 Ford Clutch Install
You will need to manage the rear spring, leave it on car or axel so you may need a spreader. Floor jack obviously, something to support engine wih trans out. Safety wire for flywheel bolts if you remove it. I like the clutch alignment tool. I don't recall needing anything special for removing the bearings but i had engine out. The manual I have instructs that a spacer is placed under the clutch fingers during removal, I think it unloads the bolts so the last couple threads aren't pulled out by spring pressure during pressure plate removal. I don't recall anything else, I am sure some of the other guys here can provide more info. Good luck and use your head to preserve your skin when you improvise.
05-20-2015, 09:34 PM | #3 |
Sofa King, What manual do you have?
As for the rear end--I just unbolt the rear spring from the frame and move the whole combine out of the way. Thanks for the reply SofaKing. Any additional advice or information from the Ford Barn crowd greatly appreciated. |
05-20-2015, 09:59 PM | #4 |
Do yourself a big favor and have tbe flywheel surfaced.
05-20-2015, 10:25 PM | #5 |
Tony, If I am replacing a clutch and pressure plate, I usually prefer to pull the engine, rather than remove the rear and transmission, because in most cases, the flywheel needs to be removed for resurfacing. I feel it is easier to remove the oil pan, to take the flywheel off, when the engine is out of the car. Also, replacing the pilot bearing is easier when the flywheel has been removed. This is just my opinion, others here may disagree.
05-21-2015, 12:04 PM | #6 |
05-21-2015, 02:38 PM | #7 |
[QUOTE=TonyM;1089450]Sofa King, What manual do you have?
Send me a PM with your e-mail and I will send you the clutch pages. It is a reproduction of a Ford manual, I think I got it off E-bay for about 20$ last year. Lousy choice; remove driveline from underneath and then try and support engine while at the same time removing the oil pan or pull engine and hassle with the radiator and hood clearance/removal. Personally I prefer to stand as opposed to crawl around unless I hope to take a brief nap or sneak some more beer. |
05-21-2015, 11:18 PM | #8 |
Does the oil pan need to come off to replace the clutch/ remove flywheel to have surfaced?
05-21-2015, 11:41 PM | #9 |
fftoddster: The clutch can be removed without removing the pan. The pan has to come off for the flywheel to be removed.
Thanks to all who responded. |
05-22-2015, 11:23 AM | #10 |
05-22-2015, 12:51 PM | #11 |
Unless your a lucky fellow and the engine has the truck pan with the removable rear section, with this you can pull the flywheel and or your 11" clutch and leave the pan on. (you can't remove an 11" clutch with a stock car pan bolted on)
I'm a lucky fellow. Martin. |
05-22-2015, 04:06 PM | #12 | |
05-23-2015, 02:01 AM | #13 |
John,
They are the best, I couldn't decide which clutch to use on my pickup, so with trans out and a jack under the pan. I swapped clutch/flywheel combos till I got the setup I liked. (I'm going for light pedal pressure do to useless knees) no dropping the pan, just swapped away. After this pan came about Ford should have just made this type, a dropped the one piece chap. Martin. |
03-17-2016, 07:27 PM | #14 |
Fredb...I need to replace a water pump and also the clutch and pressure plate. I thought that I would do both jobs by pulling out the engine. I have not done that before, but you seem to have. Can you provide me a description of the process for doing that?
Joe/Ct "The older I get, the better I was" |
03-17-2016, 09:49 PM | #15 |
Do yourself a favor and have a longer flex line made. It goes from the torque tube to the frame. It is by the transmission .Make it long enough to slide back the rear end and remove the transmission. This will save you from having to bleed the brakes.
