10-15-2015, 04:06 PM | #1 |
i need help-with 33
Three questions -after alum intake and heads are beaded and polished -how do you keep them from corroding? #2- where do I get head gaskets that will fit the expensive orig aluminum heads from water passage corrosion? #3- what kind of coolant or additive will stop the corrosion? Please help. regards T bones Thank you Ford Barn-Great Website
10-15-2015, 04:24 PM | #2 | |
Re: i need help-with 33
I use Best Head Gasket # 507G as seen here: > http://www.bestgasket.com/pop_up_pic...artNumber=507G Where to buy Best Gaskets here: > http://www.bestgasket.com/distributors.asp I don't worry about external corrosion of the intake manifold or heads....
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 10-15-2015 at 04:32 PM. |
10-16-2015, 07:49 AM | #3 | |
Dale |
10-16-2015, 09:02 AM | #4 |
Bored-&-stroked
Does the clear ceramic turn "White" when exposed to heat???? I know if you if you shoot them with straight clear...it turns a funky whitish, greyish, greenish color. |
10-16-2015, 03:50 PM | #5 |
