Old 07-24-2021, 10:49 AM   #1
Randy Lausch
Default What model A would this be
Found this number on my frame, has a star, then ax3 8159 . I’m not 100% sure the 3 is a 3
Randy Lausch is offline   Reply With Quote
Old 07-24-2021, 11:50 AM   #2
Charlie Stephens
Default Re: What model A would this be
I have seen the "X" before and always thought they were trying to track something or maybe the was an accidental duplication of the number on the engines and the "X" was added to make the number different when they added it to the frame. There should also be another star at the end of the number so you haven't found the complete number. Where on the frame did you find the number. How about a picture as the fonts used are important.
Charlie Stephens
Old 07-24-2021, 11:51 AM   #3
Charlie Stephens
delete duplicate
Old 07-24-2021, 11:58 AM   #4
Russ/40
Russ/40's Avatar
Here is what i think it is: *AX2817179*
Russ/40 is offline   Reply With Quote
Old 07-24-2021, 12:13 PM   #5
burner31
burner31's Avatar
That is what I see also
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 07-24-2021, 12:15 PM   #6
Charlie Stephens
Thanks Russ and burner. Unfortunately that is a photo I posted to show the "X" and not the frame in question.
Charlie Stephens
Old 07-24-2021, 12:37 PM   #7
Randy Lausch
Star A x318159 star
Old 07-24-2021, 06:25 PM   #8
chrs1961815
chrs1961815's Avatar
That engine number would put the engine somewhere in August 1928. Frames were sometimes stamped with engine numbers that were up to three months old.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 07-24-2021, 10:35 PM   #9
CWPASADENA
CWPASADENA's Avatar
I think you are asking about the "X".
I have never seen a "X" as part of a frame number.
Can someone tell us exactly where this came from?
Chris W.
CWPASADENA is offline   Reply With Quote
Old 07-26-2021, 01:14 PM   #10
Bud
Bud's Avatar
X as I recall from an article in one of the national magazines was for a Model A where the factory was doing something experimental. The article I recall concerned a 1930 or 31 3 window coupe restoration.
Bud is offline   Reply With Quote
