07-26-2021, 10:38 AM | #1 |
Transmission front shaft
If all you want to do is pull the front shaft out of a 3 speed, what do you have to do? I think it is called the "main gear" but whatever you call it, it's the one that drives from the pressure plate.
07-26-2021, 11:47 AM | #2 |
Re: Transmission front shaft
The red book should walk you thru it. |
