08-14-2021, 11:29 AM | #1 |
Engine RPMs
What speed do you find yourself shifting into 3d? Is there a chart of RPM v. MPH for each gear in the Model A? I find myself driving around town in 2d at higher revs, because the engine seems happier than at low revs in 3d. What's your experience?
Love this car. |
08-14-2021, 11:41 AM | #2 |
Re: Engine RPMs
A previous FordBarn thread gave lots of opinions on this.
https://www.fordbarn.com/forum/showt...9608&showall=1 |
08-14-2021, 11:50 AM | #3 |
Re: Engine RPMs
1-2 at 5-8 mph
2-3 at 12-15 mph Thats per owners manual 30 mph is just fine in high gear, but, its up to you |
08-14-2021, 01:01 PM | #4 |
Re: Engine RPMs
Attached some Model A RPM information.
Tom Endy |
08-14-2021, 01:13 PM | #5 |
Re: Engine RPMs
As long as you're not "lugging" the engine you'll be okay.
Paul in CT |
08-14-2021, 06:30 PM | #6 |
Re: Engine RPMs
08-14-2021, 07:13 PM | #7 |
Re: Engine RPMs
Here's a table I made mapping RPM to MPH based on the gear ratios. It lines up pretty closely with the mapping in Tom's article. A good rule of thumb is that your RPM for a given speed in 2nd gear is approx. twice the RPM for that speed in 3rd gear. So to upshift, you drop the RPM by half, and to downshift you double it.
08-14-2021, 07:49 PM | #8 |
Re: Engine RPMs
So if you're good cruising around at 45-47 mph (2,000 RPM) why wouldn't you be comfortable upshifting from 2nd at 25 mph? Why would you upshift at 12-15 mph? (only 950-1,200 RPM)
Upshifting to 3rd at 12-15 feels way too luggy for me. |
08-15-2021, 10:10 AM | #9 | |
Re: Engine RPMs
I upshift and downshift usually at 20-25. Like I put in the post, those speeds came right from Ford. |
08-15-2021, 04:38 PM | #10 |
Re: Engine RPMs
One of the things to consider when using Ford’s data is the conditions of the roads in ‘28 - ‘31. Those numbers sound good if you’re driving on a dirt two track.
No restorable Model A's were harmed in the building of this truck! |
08-15-2021, 06:14 PM | #11 | |
Re: Engine RPMs
I suspect those are upshift speeds for gentle acceleration on level ground so mileage is optimized. |
08-15-2021, 10:07 PM | #12 |
Re: Engine RPMs
I shift 1st to 2nd at 10 mph. 2nd to 3rd at 20 mph. 3rd to Mitchell OD (26%) at 40 mph. I think there are those that believe an engine is only good for so many revolutions, so they may try to conserve them.
08-15-2021, 11:07 PM | #13 |
Re: Engine RPMs
Getting back to the original question, one of the sales pitches for the original Phillips automatic spark advance was that you could shift into 3rd at lower speeds. It could be that drivers' preference for when to shift into 3rd is partly a function of where they park the spark lever while driving.
08-16-2021, 12:15 AM | #14 |
Re: Engine RPMs
20 on the low end and 25 on the high for me depending on road conditions. Any slower than 20 would be out of the question for me and most of my shifts into 3rd are around 23.
08-16-2021, 05:58 AM | #15 | |
Re: Engine RPMs
Don't ask me, I'm just repeating what the book says. If you need more clarification then you'll have to wake up Henry and ask him. |
08-16-2021, 06:01 AM | #16 |
Re: Engine RPMs
08-16-2021, 07:54 AM | #17 |
Re: Engine RPMs
08-16-2021, 08:13 AM | #18 | |
Re: Engine RPMs
I think I'd follow an experienced modern Model A engine rebuilder's advice, or a consensus of rebuilders, more than a 93 year old book. |
08-16-2021, 09:16 AM | #19 |
Re: Engine RPMs
Not sure I agree with this statement, low manifold pressure would indicate lugging.
The Master Cylinder Enjoying life at the beach in SoCal... |
08-16-2021, 09:46 AM | #20 |
Re: Engine RPMs
I often feel sad for those who have never driven a Model A Ford. There can be no finer sound than starting out from a stop sign and getting up to 10 mph, going to second and hearing the new sound of second gear at 15 mph with a fairly new, rebuilt transmission. There is no reason to drive any quicker, the Model A is made to do some lugging. That is why it is geared to go around corners without downshifting. The key word is to be "gentle", enjoy the ride and allow the car to provide the longevity that is built into it. Ed
