Old 07-02-2021, 05:52 PM   #1
vonpahrkur
Default difference between 1936 and 1939 frames
wondering if someone could tell me what the difference between a 1936 frame and a 1939 frame is, if anything. thanks.
also are the body mount holes the same?
Looking for original 1932 3-window coupe parts to complete my project. Also looking for 1936 ford roadster body /parts. Lots of 1941 Mercury convertible parts for sale.
vonpahrkur is offline   Reply With Quote
Old 07-02-2021, 07:08 PM   #2
bbrocksr
Default Re: difference between 1936 and 1939 frames
They are similar, Anything to do with brake mounting holes are different, rear transmission mounting holes are different, lots of little things.
A lot of people say they're interchangeable and they are with minor modifications.
If you're putting a 39 frame under a 36 and using 39 brakes an 39 rear trans mount it wouldn't be much of a problem.
Bill
bbrocksr is offline   Reply With Quote
Old 07-02-2021, 08:14 PM   #3
Kube
Kube's Avatar
cross members
Old 07-02-2021, 08:37 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
And, depending on whether you have a LATE, or an EARLY '36 chassis, the rear frame horns differ between late and early, as seen in this crude drawing. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 07-02-2021, 08:45 PM   #5
Charlie Stephens
Serial Number? Don't laugh. If you get a DMV that goes by the book they may want to register the year of your car as determined by the serial number on the frame.
Charlie Stephens
Old 07-02-2021, 08:46 PM   #6
Newc
Newc's Avatar
39 dlx uses the dipped front crossmember- for the crank mounted fan Newc
Old 07-02-2021, 09:41 PM   #7
flatjack9
flatjack9's Avatar
My 36 roadster is on a 39 frame. Installed the 36 front crossmember.
Old 07-03-2021, 11:03 AM   #8
vonpahrkur
Thanks, didn't know this. also wondering about the two mounts on the back part of the frame on the sides, one is a rectangular box before the pickup and the other is a pad-like box that is narrow at one end then wider-are these the same from 35-39 and through 40? Also do pickups have these same mounts on their frames?
Old 07-03-2021, 11:56 AM   #9
V8COOPMAN
V8COOPMAN's Avatar
I won't stick my neck out there as far as those ancillary mounts are concerned and say that they are the SAME, 'cuz I ain't sure. But, the pick-up truck frames, although the same layout as car (per year model), DO NOT have those additional mounts. DD
T5 W/TORQUE TUBE
Old 07-03-2021, 12:03 PM   #10
Krylon32
Might be a difference in the radiator mounts?
Krylon32 is offline   Reply With Quote
Old 07-03-2021, 12:33 PM   #11
vonpahrkur
okay, that's good to know about the pickup frame not having those mounts. Anyone else know about those mounts on the sides of the frame where the kickup begins and if they are the same on a 36-39 passenger car frame and possibly a 40 passenger car frame?
Old 07-03-2021, 01:41 PM   #12
V8COOPMAN
V8COOPMAN's Avatar
Front Crossmembers
1935-'36 Below
1939 Chassis Below
1940 Below
T5 W/TORQUE TUBE
Old 07-03-2021, 02:28 PM   #13
flatjack9
flatjack9's Avatar
Radiator mounts on the cross member and has to be changed.
Old 07-03-2021, 02:29 PM   #14
flatjack9
flatjack9's Avatar
as far as I remember they were the same. I didn't need to add anything.
Old 07-03-2021, 02:40 PM   #15
vonpahrkur
[QUOTE=V8COOPMAN;2032503].
Thanks! V8Coopman, that makes it completely clear.
Old 07-03-2021, 02:41 PM   #16
vonpahrkur
Thanks!
Old 07-03-2021, 02:48 PM   #17
vonpahrkur
Thanks!
Old 07-03-2021, 04:17 PM   #18
Krylon32
When I was building 35-40 chassis for customers I used the body mounts from Chassis Engineering on all car frames. P&J's is now making them.
Old 07-03-2021, 05:32 PM   #19
Antiquer
I have a pair of '36 Roadster doors that I'd sell.
Bill Daniel, (417) 793-3007
Antiquer is offline   Reply With Quote
