08-16-2021, 01:25 PM | #21 | |
Re: 81A Big A Heads
08-17-2021, 06:59 AM | #22 |
Re: 81A Big A Heads
B&S
Keep reading your last post , find it very interesting and open up interesting history of out Flatmotors
"I can't cry as long as I know the Lord has risen " |
08-17-2021, 07:11 PM | #23 |
Re: 81A Big A Heads
One thing us 'Flathead Guys' have learned over the years is that having a consistent .040 or so squish over the piston is key for turbulence and overall performance. It doesn't matter if it is a Harley KR, a Cadillac or a Ford flathead . . . same deal with all of them.
08-17-2021, 08:11 PM | #24 |
Re: 81A Big A Heads
[QUOTE=Bored&Stroked;2046702]There is also a very rare 81AS head - which a friend of mine from Finland has a set of. They are a special high-compression design - and look just about the same as most of our aftermarket chambers (like Edelbrock, Navarro, etc).
I'd love to find a set of these . . . well, just because . . . Yeah, good luck in your search! I had found a pair at Hershey many years ago. NOS and aluminum to top it off. That (aluminum) made them even more rare. Paid an insane price for them but needed them for a at that time future restoration of a very rare '40 Ford Convertible Coupe.
08-19-2021, 09:11 PM | #25 | |
Re: 81A Big A Heads
[QUOTE=Kube;2047163]
On that picture of the engine where is the radiator cooling fan located? Thanks, Phil NZ |
08-19-2021, 10:11 PM | #26 |
Re: 81A Big A Heads
On that '40 the fan with short extension will be mounted directly to the end of the crankshaft. If you look very closely I believe the tip of a blade can be seen near the distributor. Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick) '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" 302 |
08-20-2021, 06:06 AM | #27 | |
Re: 81A Big A Heads
Did you notice the deeper domes as well? |
08-20-2021, 11:46 AM | #28 |
Re: 81A Big A Heads
