08-19-2018, 03:01 PM | #21 |
Re: slipping out of 2nd gear
Frank West I’ve used this part and it works but it’s a bandade
"I can't cry as long as I know the Lord has risen " |
08-19-2018, 03:19 PM | #22 |
I've always heard this is a deluxe transmission with the auto-neutral feature. Just saying...
08-19-2018, 04:56 PM | #23 |
Please understand that the transmission he has is a early type.. All these "band-aid" fixes are relative to the later 39-up transmission when refering to the plungers and spring between the shift rails. The Early 32-37 transmissions had ONLY the plungers and spring between the rail. So..... the part he shows in post #20 is NOT a band aid fix but rather a stock replacement part for the 32-37 transmission. I am betting money this is not his issue..
08-19-2018, 07:54 PM | #24 |
if my original spring has fractured this replacement may be just what I need. Like I said,
When I first got my car running it was not jumping out of and gears, so maybe with the operation of the gear changer work hardened 80 years old springs fractured? I is worth a shot, as long as I can get at the original part. I assume removing the transmission floor cover will allow me access. |
08-19-2018, 09:14 PM | #25 |
While it is a possible cause, I’ve never seen one break. You’ll need to remove the whole shifter assembly and remove the 2-3 shift fork and rail to replace. You’ll also need a 3/8” freeze plug to replace the one you’ll remove to replace the detent..
08-20-2018, 02:15 AM | #26 |
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me. |
08-20-2018, 10:46 AM | #27 |
08-20-2018, 01:01 PM | #28 |
The key word is basic. The 32 thru 35 transmissions were a lot better than the Model A with no synchro at all. The single detent vertical tower shift top came along in 1936 with other transmission improvements. The double detent type tower came along in 1938 or so. The side shifters from 40 thru 48 can also wear to the point they will pop out of gear. The flaw in all equipment is that they all wear out eventually. Some just wear out quicker than others.
08-21-2018, 06:02 AM | #29 |
Thanks.....You are right..everything wears, especially 85 year old cars...These engines and transmission are very well made considering they we built as a cheap form of transportation for the masses.
07-06-2022, 11:57 AM | #30 |
Problem solved.....No more slipping out of gear....
What happened? I drained transmission fluid and replace with Marvel Mystery Oil.... Drove only a couple of miles,, Drained the Marvel Mystery Oil. Replaced new transmission/gear oil. No more popping out of gear. Did the MMO clean the trans so that it would operate properly..Maybe magic.?? |
07-06-2022, 12:16 PM | #31 |
Brace yourself Frank, you might get some feedback on this one !
07-06-2022, 02:05 PM | #32 |
Like Douglas MacArthur, it shall return.
07-06-2022, 02:10 PM | #33 |
07-06-2022, 03:31 PM | #34 |
07-06-2022, 03:37 PM | #35 |
Of course.
When I first bought my car, people on this forum told me not to run it but take the engine all apart first to inspect it. It will not post anymore on here. I just tried to tell of a simple possible fix.'' Don\t worry I will not post anymore on here |
07-06-2022, 03:54 PM | #36 |
Well geez Frank, can't a guy put some humor in here without rocking the boat ? I certainly meant no insult, only some humor. Please don't run off, I always enjoy your adventures with your 33
07-06-2022, 03:57 PM | #37 |
07-06-2022, 03:58 PM | #38 |
07-06-2022, 05:41 PM | #39 |
Because it is a common, wear-related occurrence and eventually happens to just about all of them. Search this forum and you will find that you are not the first to experience 2nd gear pop-out on deceleration.
07-06-2022, 06:06 PM | #40 |
The reason I know is that I've spent countless hours rebuilding these transmissions - even going so far as to make my own cluster shafts, adding special "hard stops" on the shift rails, using a precision surface grinder to tune clearances, etc..
I've had multiple transmissions with the same problem you're experiencing -- so I fix them and if they are ran for a few years and abused (I'm hard on them), then they'll be back in this situation at a later date. The "fix" is complicated in that it involves trying to fix all the compounded "slop" in the fitment of the various pieces -- shims, bearings, shafts, etc.. I try to achieve the tightest clearances possible (on the low end of every spec) - and that usually works . . . at least for awhile. If we all had a supply of NOS parts, it would be a lot easier . . . but most of those supplies have dried up over the years. So, not trying to deliver bad news to you - just trying to be honest (based on the last 45 years of screwing with these transmissions). Best of luck - please stay around! B&S |
