Old 04-07-2021, 07:44 PM   #1
Don
Don's Avatar
Default Fuel pump just as a pass thru
What’s a safe way to just use .org, fp as a pass thru using a electric pump??
Do you need to remove the check valves ?? Replace dia.with a plate ?.
DON P
Don is offline   Reply With Quote
Old 04-07-2021, 08:29 PM   #2
Andy
Default Re: Fuel pump just as a pass thru
Just leave it stock. I have used boost pumps running thru the stock pumps on many cars.
Andy is offline   Reply With Quote
Old 04-07-2021, 09:08 PM   #3
drolston
drolston's Avatar
Ditto on leave it stock. That way, if the electric fuel pump fails, you get home. Just be sure to use an electric fuel pump that does not block flow when it is off. I use Mr. Gasket 42S because it puts out only 3 psi which won't flood a flathead. Mine is 12 volt. Not sure if you can get it for 6 volts.
Old 04-08-2021, 07:44 PM   #4
JSeery
JSeery's Avatar
That's fine until a diaphragm splits and you fill the crankcase up with fuel.
Old 04-08-2021, 08:56 PM   #5
Don
Don's Avatar
That what needs to be avoided,any ideas,,put a stainless disc in place of rubber ?.
DON P
Old 04-08-2021, 10:06 PM   #6
1952henry
1952henry's Avatar
Iirc, Vic Piano modified a fuel pump for pass through.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 04-09-2021, 06:58 AM   #7
69a
Use a metal disc and use Viton, EPDM
69a is offline   Reply With Quote
Old 04-09-2021, 09:14 AM   #8
40cpe
40cpe's Avatar
Vic Piano did the conversion and detailed it in his thread entitled "What I did on my lunch hour". The problem is that only the most recent 20 pages of that thread are archived and available. He did the conversion prior to about 2015 and we can't read back beyond that time.
40cpe is offline   Reply With Quote
Old 04-09-2021, 09:57 PM   #9
drolston
drolston's Avatar
Good point. But that is a risk that is avoided by rebuilding the pump with a kit using ethanol resistant materials, and an electric pump that puts out less pressure than a stock fuel pump - which is about 4 psi.
Old 04-09-2021, 10:53 PM   #10
Tinker
Tinker's Avatar
Vic did one as mentioned. The concept is pretty easy. Remove either the fuel pump rod or the lever action unit in the fuel pump, then replace the diaphragm with a tin plate.
I don't like the sound of a electric pump so I use a mechanical. I'm not saying doing it either way. But if the motor dies for some reason the mechanical pump stops. Electric will keep pumping gas even if the motor is upside down. So now we are into enrsa setups...
