Old 08-22-2016, 05:55 PM   #1
rbullockv8
rbullockv8's Avatar
Default Transmission drain plug
Wondering what you guys use on a transmission drain plug to seal it. Whatever goop I used a year or two ago, the plug began leaking right away. Since I had a big pan under it, I put it off while working on other things.
Drained out the oil today. There are no visible cracks in the trans, threads are good on boss and plug, and seems to be leaking right past the threads. I don't mind some engine sweat, but don't want a 50 cent piece each day.
I've got some Permatex from my gas tank sender I can use. Or is teflon tape better? (In a web search, I see other car guys of all makes sometimes use tape).
What's your experience?
By the way, got the chassis rolling on four tires yesterday for the first time. Making steady progress. Just got to get this pesky trans leak fixed.
Thanks
1932 Model B Roadster Pickup
rbullockv8 is offline   Reply With Quote
Old 08-22-2016, 06:05 PM   #2
Terry,OH
Terry,OH's Avatar
Default Re: Transmission drain plug
It could be the rear of the transmission leaking down to the drain plug and making it look as if the plug is leaking. There are two shafts at the rear of the transmission that are very prone to seeping fluid leaking out
Old 08-22-2016, 06:10 PM   #3
rbullockv8
rbullockv8's Avatar
Nope. The trans case is dry. It's still a non-driving car and hasn't moved from the garage. But I'll keep an eye on those rear seals when I get it going. Good thought.
Old 08-22-2016, 06:18 PM   #4
RKS.PA
RKS.PA's Avatar
Try some teflon tape wrapped clockwise on the plug and don't be afraid to snug it down. See if that helps.
RKS.PA is offline   Reply With Quote
Old 08-22-2016, 06:45 PM   #5
Talkwrench
Talkwrench's Avatar
My thoughts the same as Terry . But try Permatex non hardening ..
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 08-22-2016, 06:48 PM   #6
rbullockv8
rbullockv8's Avatar
Terry,OH, I apologize. I think you might be right. I got a better work light under there to tighten the wishbone cap and put in the cotter pins, and I saw a slight reflection of a very thin line of trans oil trailing down the back slope of the trans case. Couldn't see it before. I will hope that seals with some revolutions, but if not, I might be trying some of that BlueDevil product. Sure don't want to pull this whole thing apart. So much for a professional rebuild. Hope the rest of the trans innards hold up. :-)
Old 08-22-2016, 07:01 PM   #7
RalphM
RalphM's Avatar
I always use a product called Green Stuff, made by jomar.
Works on fuel oil and coolant fittings, it dries, but never gets hard and brittle.
Used it for many years, should be avail from any pipe supply.
RalphM is offline   Reply With Quote
Old 08-22-2016, 07:28 PM   #8
39portlander
39portlander's Avatar
Maybe to help fill in your blanks.... Order Mac Van Pelts "In's and Out's of Early Ford Transmissions" pretty sure you had a "professional rebuild", these 3 speeds leak @ the rear shaft areas.
In Mac's "In's and Out's" page 52 General notes clearly talks about and explains your/our issue which Terry noted in his reply and Mac talks about specifically in the general notes third paragraph, "prone to seepage" @ the 7140 Idler and 7111 counter shafts.
Now I remember a web site that did have replacement Idler/counter shafts with "O" rings that did help with this condition and may involve a re-bush @ the case openings if it's a few thousandths larger than the shaft but your not alone with the drips brother...we all got'um. Scott
39portlander is offline   Reply With Quote
Old 08-22-2016, 07:35 PM   #9
JM 35 Sedan
JM 35 Sedan's Avatar
If I use anything at all on those transmission/banjo rear drain plugs, and most times I don't, it would be 3-4 wraps of Teflon tape and snug those plugs down good. However, I would never use Teflon tape on any areas of the engine oil system or any gas line connections where little pieces of Teflon could windup plugging oil or gas flow. Probably more info than you asked for or needed, but I'm just sayin'.
John
Old 08-22-2016, 07:45 PM   #10
JM 35 Sedan
There was a recent post here, i think, describing how someone came up with a good and unique way to plug the ends of those counter shafts, and locking pin holes, to stop that leak which normally occures at the rear of these early Ford 3 speed transmission cases. Don't recall exactly when, or on which thread I saw that. I'm sure someone good at remembering things, like DD, or someone good at doing searches, like DD again, could find this.
John
Old 08-22-2016, 08:23 PM   #11
Terry,OH
Terry,OH's Avatar
There are no seals on the shafts. When I rebuild I use new shafts with O-rings on the shafts. Try some of the ideas above to seal them.
