Old 07-01-2015, 10:58 AM   #1
Brubaker
Brubaker's Avatar
Default hub cap tool
Just out of curiosity, how does a 'hub cap tool' such as sold by Mike's work exactly? Installation is basically bending the tabs over securely, correct? I must be missing something(?).
Brubaker is offline   Reply With Quote
Old 07-01-2015, 11:39 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: hub cap tool
The tool gives the tabs a slight V shape so the cap can be pushed on and snapped off.
Old 07-01-2015, 12:57 PM   #3
Brubaker
Brubaker's Avatar
Thanks Tom. If I could ask for a personal opinion, worth the fifty bucks? Bruce
Old 07-01-2015, 01:53 PM   #4
Y-Blockhead
Y-Blockhead's Avatar
I know others will suggest glueing them on with silicone or rubber bands but after you lose a couple of hub caps or mess up the paint on your wheels from a cap chattering around you"ll think $50 is cheap. The "Tool" bends five of the 10 tabs to the correct shape to hold the caps on. I have also saved a few caps that had all of the tabs bent.
If you have any friends with '30-31 Model A's you could all "chip in".
I have not had a problem with a hub cap since I bought the "Tool" last July and have "Fixed" several for friends.
Old 07-01-2015, 02:11 PM   #5
C26Pinelake
i personally think they are great and I bought one as a Christmas Gift for a friend, Wayne
C26Pinelake is offline   Reply With Quote
Old 07-01-2015, 03:53 PM   #6
Fullraceflathead
Fullraceflathead's Avatar
I'd like to have one for my 1928, but they don't exist.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 07-01-2015, 04:01 PM   #7
monto
monto's Avatar
Before I was aware the "tool" was available, I made it work using a 3/8 coupling nut. You screw a short bolt into each end so the contraption matches the diameter of the cap. Then place it between two opposing tabs. When you tighten one of the bolts it spreads the tabs to where you want them. Slow and clumsy, but it works.
monto is offline   Reply With Quote
Old 07-01-2015, 11:05 PM   #8
Tom Wesenberg
I never used the tool, so I can't offer an opinion.
