Old 04-05-2013, 06:53 AM   #1
Racur96
Racur96's Avatar
Default Quail cap
Hi guys, from what I've read this is a repro right?
Racur96 is offline   Reply With Quote
Old 04-05-2013, 07:01 AM   #2
donh
Default Re: Quail cap
Mine was a repro. I bought it from Bratton's. I have gone to a temp gauge hooked up to the water outlet vs the quail . Easier to really see what is going on temperature wise.
I'm not sure I have ever seen a real quail radiator cap.
donh is offline   Reply With Quote
Old 04-05-2013, 09:13 AM   #3
Big John
Definately a repro... ...
Big John is offline   Reply With Quote
Old 04-05-2013, 10:44 AM   #4
Purdy Swoft
Purdy Swoft's Avatar
Its a reproduction. The original accessory quail caps were not thermo quails and didn't have the thermometer.The Vintique repro quails are bad about ruining the radiator neck, I've messed up two radiator necks over the years by using them. I use the repro Rexaco temperature gauge with the sending unit connected to a metal pipe in the upper hose. I didn't want to run the risk of breaking an expensive upper water outlet with the threaded hole for the sending unit.
