Old 04-26-2021, 10:54 AM   #1
JayJay
Default Torque spec for spark plugs?
I am likely being waaaay too anal, but is there a torque spec for the spark plugs on the original head? In the back of my mind I recall seeing one but can't find it in any of the references I have on hand.
Otherwise, snug plus a scoch will have to do.
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
Old 04-26-2021, 11:15 AM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Torque spec for spark plugs?
Use original wrench,as tight as you can get with one hand
Old 04-26-2021, 11:46 AM   #3
Patrick L.
Patrick L.'s Avatar
I like such workable technical terms !
Old 04-26-2021, 04:56 PM   #4
fried okra
Location: Daniel Island,SouthCarolina/Knoxville, Tennessee/Sanibel Island,Florida
Seems like I recall seeing....and using......one for about 15 ft/lb recently.
fried okra is offline   Reply With Quote
Old 04-26-2021, 06:03 PM   #5
J Franklin
J Franklin's Avatar
I think an original wrench, tightening by hand, would be more than 15ft/#, especially back in the day when men were stronger, and didn't want a plug shoot through the hood out in nowhere land!
Old 04-26-2021, 06:43 PM   #6
McMimmcs
McMimmcs's Avatar
Waaay to anal ! Just like you said.
Old 04-26-2021, 07:36 PM   #7
JoeCB
JoeCB's Avatar
I had just posted this to a thread about manifold torque... same applies here.
"good and tight" is about right !! I suspect that about 99.9% of all Model A's lived their first 50 -60 years without ever encountering a torque wrench.
Joe B
JoeCB is offline   Reply With Quote
Old 04-27-2021, 12:54 AM   #8
redmodelt
redmodelt's Avatar
The length of the original wrench would get you more like 45-50 FPs if you pulled them real tight. They don't need to be that tight. Just snugged down so they don't leak past the sealing washers.
Old 04-27-2021, 10:37 AM   #9
JayJay
Thanks, all. I've spent a lot of time working on BMW motorcycles where engine and tranny parts are either aluminum or magnesium, and torqueing to spec is pretty critical. I'm as interested in consistency as I am in the value. I'll mess around and see what feels right and develop a spec from that, I suspect it's going to be in the 20-25 ft-lb range (about half of the head nut spec of 55 ft-lb).
JayJay
JayJay
Old 04-27-2021, 11:25 AM   #10
jayvee34
jayvee34's Avatar
I'm with you this. Go beyond that and you will have a problem getting them loose, especially on aluminum heads.
jayvee34 is offline   Reply With Quote
Old 04-27-2021, 12:35 PM   #11
nkaminar
nkaminar's Avatar
A little anti seize on the threads will help with consistent tightening and help when it comes time to remove the plugs, especially with aluminum heads.
Old 04-27-2021, 04:39 PM   #12
Benson
Benson's Avatar
Head types that is: C. I. vs Aluminum and thread size matters see tables here.
Following info is from this URL:
https://ricksfreeautorepairadvice.co...k-plug-torque/
Old 04-27-2021, 04:51 PM   #13
JayJay
This is interesting. So for a 7/8" thread and cast iron head (Model A), this table recommends 50-55 ft-lb, or around the same as the head nuts. That just seems high to me.
JayJay
JayJay
Old 04-27-2021, 07:49 PM   #14
tinkirk
tinkirk's Avatar
JayJay
Tight is tight too tight is broke??
tinkirk is offline   Reply With Quote
