01-24-2024, 08:45 PM | #1 |
Distributor shafts - one piece or two piece?
I would appreciate some education on distributor shafts. Any preferences one way or the other? Advantages of one over the other? Personally I like the one piece shaft.
01-24-2024, 09:20 PM | #2 |
Re: Distributor shafts - one piece or two piece?
All mine are two piece. The one piece shaft causes premature wear of the bushings since it is completely rigid. The two piece shaft permits a slight amount of misalignment caused by poor concentricity of the mounting hole in the head. Sort of acts as universal joint.But they both do work.
www.whidbeymodelaclub.com |
01-24-2024, 09:23 PM | #3 |
Agree with Gary !
01-24-2024, 09:30 PM | #4 |
Understood. Makes perfect sense.
01-25-2024, 09:50 AM | #5 |
Every one piece shaft that I have seen, is bent, and we replaced them with two piece shafts.
This alone solved a lot of engine noise on those engines. |
01-25-2024, 10:33 AM | #6 |
01-25-2024, 11:04 AM | #7 |
The January 1928 Parts Price List shows a 2-piece shaft, so I doubt that the one-piece shaft is an authentic Model "A" design. The original parts are A-12178 Distributor Cam Shaft & A-12249 Distributor Coupling Shaft. The same part numbers are in the July 1 1931 Parts Price List. The December 1932 Parts Price List has the A-12178 Shaft listed for 1928- 1931, and a B-12249 (was A-12249) for 1928 - 1932. The B-12249 is the only shaft listed for 1932. Could it be that the B-12249 Shaft is the 1-piece shaft?
I have always used the 2-piece shafts.
Bob Bidonde |
01-25-2024, 11:11 AM | #8 |
Thanks Bob. You're information is always very helpful.
01-25-2024, 11:32 AM | #9 |
A rigid, one piece shaft with non aligned bushings will cause interference. With two pieces, the extra joint allows for a slight amount of forgiveness.
