Old 12-21-2023, 12:08 PM   #1
Bob Bidonde
Bob Bidonde's Avatar
Default Gauges, Meaningful Ones
I have an accessory gauge mount the goes on the steering column and has room for 2 gauges. My car already has a temperature gauge, and it has a Model "B" engine. What 2 gauges do you suggest I put into the steering column bracket?
Bob Bidonde
Old 12-21-2023, 12:56 PM   #2
Jim Brierley
Default Re: Gauges, Meaningful Ones
Move the temp ga. to the new mount and add an oil pressure ga.
Old 12-21-2023, 12:57 PM   #3
Banditorama
Maybe a tachometer
These things don't build much oil pressure, so I wouldn't bother with that. What might be pretty handy is an air fuel ratio gauge. But, you'd have to weld a bung in the exhaust for a wide band O2 sensor
Banditorama is offline   Reply With Quote
Old 12-21-2023, 01:11 PM   #4
petew
petew's Avatar
I have tachometer and water temp .
petew is offline   Reply With Quote
Old 12-21-2023, 02:17 PM   #5
WHN
The nice thing about having an oil pressure gauge is that you know that the oil pump is working. What could be more important?
Ours runs around 10 to 13 pounds cold and 3 to 5 pounds warm.
Old 12-21-2023, 02:24 PM   #6
nkaminar
nkaminar's Avatar
I find a voltmeter, in conjunction with the ammeter, very handy. Hook it up so that it comes on with the ignition switch. When you first turn on the ignition it will tell you how good your battery is. You can view the voltage when cranking the engine to see if the battery is good under load. While you are driving you can monitor the battery voltage. If you have an alternator it will come up to a fully charged state, 7 or 14 volts, and the ammeter will be at zero. My battery shows about 8 volts when I am cranking the engine (12 volt system).
My alternator failed once while I was on a trip to a friends house. The ammeter showed a slight discharge, but the voltmeter was a spot-on clue. I monitored the voltage while I completed the last few miles to make sure that my ignition system was going to make it. The alternator was changed out at my friends house.
The oil pressure is important, of course, but I find that I am looking at the tachometer a lot more than the oil pressure gauge. I have an overdrive so I can keep the engine rpm in the right range for the conditions, such as climbing a grade or cruising down the highway.
Old 12-21-2023, 03:52 PM   #7
petew
petew's Avatar
Neil did you ever figure out what failed on the alternator ?
Old 12-21-2023, 04:23 PM   #8
WHN
Nice looking dash!
Old 12-21-2023, 05:19 PM   #9
denis4x4
denis4x4's Avatar
Volt meter and vacuum gauge. However, an oil pressure gauge can be fun when you point out it dropped to 5 PSI to a passenger!
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 12-21-2023, 08:52 PM   #10
Pete
Pete's Avatar
If you are going to have gauges, you need to have them so you can see them without distracting you from driving. That means looking at them with your peripheral vision. In other words without taking your eyes off the road.This is one of the first things you learn in racing and high performance defensive street driving school.
Mounting them so that when they are reading normal running value with the needle pointing straight up makes it very easy to recognize if something goes out of normal while driving.
Old 12-21-2023, 11:23 PM   #11
CarlG
CarlG's Avatar
I have a tachometer, water temp & clock.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 12-22-2023, 06:33 AM   #12
nkaminar
nkaminar's Avatar
Hi Pete, A wire connection failed at the end of the field winding. I cleaned up the stub and soldered it to the lead. I encapsulated the area with epoxy. I can't remember the details but that is the gist of it. The alternator is on the shelf as a spare. It appeared to be a manufacturing flaw.
Old 12-22-2023, 07:30 AM   #13
Model "A" Fords
Does anyone have an inside indicator for tire pressure?
Model "A" Fords is offline   Reply With Quote
Old 12-22-2023, 08:39 AM   #14
Bob Bidonde
Thanks all for your recommendations. My choices are a voltmeter to watch over my 12V alternator, and a vacuum gauge.
Bob Bidonde
Old 12-22-2023, 09:57 AM   #15
Big hammer
Bob I understand the volt meter, why the vacuum gauge? Inquiry mind wants to know.
get a bigger hammer tap done
Old 12-22-2023, 10:13 AM   #16
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
If you feel the need for gauges at all, why not an o2 sensor gauge that tells the fuel mixture ratio so you can adjust the GAV for the best mixture? Maybe add a Pyro or a Vacuum gauge to set the timing to optimum??
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 12-22-2023, 10:23 AM   #17
mhsprecher
mhsprecher's Avatar
I think Brent has a great idea. I'd love to see how to do that. I assume mounting it inside the muffler. Brent, tell us what to do here.
1924 Model T Coupe
1928 Model A Roadster
1930 Model A Town Sedan
1939 Deluxe Fordor
1945 pickup
1951 Custom convertible
mhsprecher is offline   Reply With Quote
Old 12-22-2023, 11:28 AM   #18
petew
petew's Avatar
TPMS for rv's . Check Amazon
Old 12-22-2023, 12:11 PM   #19
WHN
Brent, are you being serious or messing with peoples minds?
Happy Holidays to all.
Enjoy.
Old 12-22-2023, 12:22 PM   #20
BRENT in 10-uh-C
Enjoy.
Air/Fuel Gauge Selection;
https://www.jegs.com/c/Gauges-Tachs_...10625/10002/-1
EGT Gauge Selection;
https://www.jegs.com/webapp/wcs/stor...yrometer+Gauge
BRENT in 10-uh-C
