Old 09-27-2022, 06:17 PM   #1
HalcyonDays
HalcyonDays's Avatar
Default Late '31 shut off valve
I am attempting to clean old varnish from my late '31 gas tank. I am having good luck with denatured alcohol. The process would move along much faster if I could replace the shut off valve on the tank with a barbed fitting. Does anyone know the tread size/count of the male adapter that would screw into the tank fitting?
My thought would be to drain the tank with this fitting attached to a hose. Any help would be great.
HalcyonDays is offline   Reply With Quote
Old 09-27-2022, 09:58 PM   #2
Big hammer
Default Re: Late '31 shut off valve
So your wanting to remove the valve and screw a fitting into the tank? 3/8 NPT You’ll want to clean out trough just inside of the removed valve .
get a bigger hammer tap done
Old 09-28-2022, 12:00 AM   #3
HalcyonDays
Thanks for that information.
Old 09-28-2022, 07:45 AM   #4
ndnchf
ndnchf's Avatar
When you get it all clean, do yourself a favor and solder a pencil filter to the inlet of your new valve. It will reduce the chance of damaging the valve seat and a leaky valve if other debris makes its way through.
ndnchf is offline   Reply With Quote
Old 09-30-2022, 08:52 PM   #5
gtovet49
gtovet49's Avatar
Interesting. Where can one get these?
gtovet49 is offline   Reply With Quote
Old 10-01-2022, 03:32 AM   #6
ndnchf
ndnchf's Avatar
The pencil filter? Most of the model A vendors sell them.
