06-26-2020, 11:19 AM | #1 |
Cornhead grease in steering
Does anyone have a process for filling Steering box with Cornhead Grease? I could use a little help here. Thanks Stan.
06-26-2020, 11:22 AM | #2 |
Re: Cornhead grease in steering
Take the filler plug off and pump it in.
06-26-2020, 11:37 AM | #3 |
Just put the cartridge in a regular grease gun and pump away. It may help to raise the front wheels and turn the steering back and forth. That’s what I did. Some people drill and tap the plug and put in a grease nipple...... Mark
06-26-2020, 11:52 AM | #4 |
PennRite Steering Box Lube.....................it doesn't leak out.
Paul in CT |
06-26-2020, 12:04 PM | #5 |
I've had good luck with this in steering boxes.
https://www.tractorsupply.com/tsc/pr...0?cm_vc=-10005 Bob |
06-26-2020, 12:05 PM | #6 |
06-26-2020, 12:12 PM | #7 |
You can put it in a tin can and put the can in a pot of boiling water for a few min then pour it right in. Take the pot off the heat source so it is no longer boiling to prevent water contamination.
06-26-2020, 12:55 PM | #8 |
I installed a zerk fitting in an extra filler plug and pump it in via that. With this method, I am 100% certain, the box is full.
Once done, I simply replace the modified cap with the stock cap.
06-26-2020, 04:09 PM | #9 |
Over on the HAMB we had a "discussion" about how much cornhead grease was appropriate in these old Ford boxes. I was of the school that fill it up to the plug was good. Others said fill it halfway to allow some expansion room.
I'd think if a guy was to install a zerk and kept filling til he couldn't anymore, he may blow it up through the top bearing and begin filling his column tube too. Discuss.... |
06-26-2020, 04:19 PM | #10 |
Make up a 1/4 tube to screw onto your grease gun ,insert into through the filler hole and down in the box and fill the box from the bottom.
Lawrie |
06-26-2020, 04:42 PM | #11 | |
06-26-2020, 07:54 PM | #12 |
common sense is a foreign idea to an old Ford nut--just my two cents worth
06-27-2020, 09:41 AM | #13 |
I use hub wheel bearing grease that 18 wheelers use in their wheel bearings. A thick liquid with stop leak.
06-27-2020, 10:58 AM | #14 | |
I wouldn't admit that in public. DD |
06-27-2020, 09:51 PM | #15 |
I just filled my steering box on the tonner with JD cornhead grease about an hour ago. I had an old giant syringe with about a 1" bore and I cut the tapered tip off a bit and at 65 degree temp it sucked up it's capacity in about 10 seconds. It took two helpings to get to just below the fill plug. I didn't want to fill my one good grease gun with something I wouldn't use up. The woodie gets the treatment tomorrow. This syringe has been handy with other fluids such as brake fluid. Maybe from a veterinary supply?
06-28-2020, 07:55 AM | #16 | |
06-28-2020, 10:30 AM | #17 |
Big Syringe: Good for filling steering boxes and basting Turkeys . . . just don't use the same one.
06-29-2020, 10:30 AM | #18 | |
Good point. Nothing quite like the aroma of hot 90w wafting from the oven on Thanksgiving......
06-29-2020, 10:41 AM | #19 |
06-29-2020, 11:14 AM | #20 | |
I dig coal, which provides motivation for EVs. |
