Old 01-20-2020, 08:57 AM   #1
dlfrisch
dlfrisch's Avatar
Default Motor Paint color ?
what color motor paint, should I use on my 1928 Sport Coupe ?
dlfrisch is offline   Reply With Quote
Old 01-20-2020, 09:04 AM   #2
ryanheacox
ryanheacox's Avatar
Default Re: Motor Paint color ?
That would be Ford engine green. There is some variation to the color depending on which vendor you go through. There is also debate as to which vendor is the closest to correct. My advice would be pick one vendor and go with it. I've used Brattons rattle cans in the past and it works well. Smells terrible but looks good.
Block, head, water inlet and outlet, flywheel housing, bell housing, transmission, tower, and rear bearing retainer all get the same color.
Old 01-20-2020, 09:30 AM   #3
dlfrisch
dlfrisch's Avatar
Thanks ryanheacox
Old 01-20-2020, 10:11 AM   #4
F.M.
Brattons; Does NOT have Engine Green in spray cans any more, only brush type.
F.M. is offline   Reply With Quote
Old 01-20-2020, 11:55 AM   #5
David R.
I used brush. Looks pretty good on cast iron and you don't have to worry about the rattle can clogging up etc.,.
David R. is offline   Reply With Quote
Old 01-20-2020, 04:06 PM   #6
Richard in Anaheim CA
Richard in Anaheim CA's Avatar
Ryan forgot intake manifold and engine crank pulley
Richard in Anaheim CA is offline   Reply With Quote
Old 01-20-2020, 04:37 PM   #7
Charlie Stephens
I have always had better luck with brush than spray. Read the judging standards for which parts are Ford engine green and which are black.
Charlie Stephens
Old 01-20-2020, 07:16 PM   #8
Bruce of MN
Bruce of MN's Avatar
I had leftover in a spraycan and used it on my new mailbox.
Old 01-20-2020, 07:23 PM   #9
whirnot
whirnot's Avatar
I use Pioneer antique Ford Engine paint ( green)
Available on Amazon. Same paint some of the suppliers used to use, not sure why they don't anymore
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 01-20-2020, 07:29 PM   #10
ryanheacox
ryanheacox's Avatar
I knew there was going to be something I missed Good catch. I see the can from Bratton's comes from Bill Hirsch. I've heard nothing but good things about that paint.
The only reason I buy rattle cans is that I've never had enough to paint where I needed a big can.
Old 01-20-2020, 07:33 PM   #11
F.M.
From Brattons on last Fridays Phone call, They can not get it any more from the Co. that made it for them and others because of a Hurricane, as all mixtures to make it were lost.. And that was there supplier, Bill Hirsch..
Old 01-21-2020, 02:31 PM   #12
Purdy Swoft
Purdy Swoft's Avatar
I agree about the possibility of the spray can stopping up . When I have purchased Ford engine green in pint cans , I have sprayed it with my Binks model 7 paint gun . When used in this manner I can add hardener for durability , it also dries quicker !!!
Old 01-21-2020, 03:12 PM   #13
alexiskai
alexiskai's Avatar
Worth remembering that originally the paint was applied pretty lightly. Here's a good thread on it from last year with some pictures.
https://www.fordbarn.com/forum/showt...6207&showall=1
Old 01-21-2020, 03:52 PM   #14
Purdy Swoft
I wonder if Ford painted head nuts and studs when the engines were painted ?
Old 01-21-2020, 07:04 PM   #15
chrs1961815
chrs1961815's Avatar
The nuts were cadmium or zinc I think, but not painted.
I mix my own engine paint to get a almost exact match out of the color book.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 01-21-2020, 07:47 PM   #16
F.M.
And you will find a lot of people say the color book is wrong, including Restoration Shops & Judges at shows..
Old 01-23-2020, 08:43 AM   #17
DD931
DD931's Avatar
I just had an engine rebuilt by Schwalms. They use Bill Hirsch paint and have for years with good experience. Engine looks great!!
DD931 is offline   Reply With Quote
Old 01-23-2020, 10:11 AM   #18
Purdy Swoft
I paint my engine block and head separately . I then put the engine together and install new cadmium-zinc plated head nuts . I figure that Ford didn't mask attaching nuts , bolts and studs , it probably would have taken too much time . The plated nuts add detail to the engine . .
Old 01-23-2020, 10:52 AM   #19
ryanheacox
ryanheacox's Avatar
Following the link to Dave Lopes Fordor, post #12 states that the castings were painted before machining. That would mean the nuts and studs are unpainted.
Old 01-23-2020, 11:31 AM   #20
Purdy Swoft
Thanks Ryan , I have often wondered about that .
