10-12-2014, 07:13 PM | #1 |
Oil fill tube loose
My oil fill tube is loose in the block, is there an easy fix for this? Wrap with Teflon tape and shove it in?
10-12-2014, 09:27 PM | #2 |
Re: Oil fill tube loose
I take a ball peen hammer and swell out the bottom end of the pipe and put it back in and it is real tight as it should be.
And like 30 Coupe, I use a Oak block to go on top of the pipe before the Lead hammer. |
10-13-2014, 04:21 PM | #3 |
depending on how loose it is i managed to get by with painting the lower end that slides in the block with paint, letting it dry till tacky then tapping it in with a hammer and a board. stuck solid now. I'm sure it would come out if i really wanted it too but doesn't come out by hand.
If its pretty loose id first make sure its round - might be able to use a small tailpipe expander to make it round/"stretch" it some. if its round as its gonna get id do what 1930 coupe said up there about the tinning with soldier and paint. I would not use teflon tape in the chance the teflon falls off inside the engine - going to clog the oil pump screen.
1929 Model AA - Need long splash aprons! |
06-16-2016, 12:04 AM | #4 |
loose fill tube for oil can be tightened by using a nail punch to dimple about 1/2 inch up on the inside to make a small dent using a small hammer to indent the inside to make a "pimple" to make the tube larger until it is secure. Make the dimples around the surface until it makes the tube tight. It works!
Swede |
06-16-2016, 01:00 AM | #5 |
Mine was loose and seeping a little oil residue.
I cleaned it and the hole in the block then sealed it with silicone. It's now tight and my clean painted block stays clean.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
06-16-2016, 05:51 AM | #6 |
If you powdercoat the tube, the thickness of the powdercoat will probably tighten it enough. |
06-16-2016, 06:53 AM | #7 |
I have used a close fitting socket in a vice and rocked the pipe around on it to expand the end some
06-16-2016, 08:46 AM | #8 |
This exhaust pipe expansion tool is ideal for fixing a loose breather pipe. The expansion tool is also ideal for restoring out-of-round and dented breather tubes. Inexpensive tools in various sizes are available from Harbor Freight.
Bob Bidonde |
06-16-2016, 09:52 AM | #9 |
Soft solder ( lead/tin) works well.
06-16-2016, 09:57 AM | #10 |
Mine was loose and weeping oil. Cleaned, painted and reinstalled it with JB Weld. Hasn't given any more problems.
I Love Anything That Turns Money Into Noise |
06-16-2016, 11:45 AM | #11 |
Like Ian said, just TIN the bottom end & drive it in. I put a smear of LOCTITE, before driving it in.
Bill Tight
