10-21-2020, 11:29 AM | #1 |
Window Riser Handles and "Show Quality" Nickel Plated Escutcheons
Has anyone attempted to use the scroll window handles and the escutcheons sold by Brattons? The handles are too big for the hole in the escutcheon.
I called them and they told me they are aware of this. Furthermore, they're not sure which part is incorrect. All they could say is that based on the source of each part (handles-China, escutcheons-A&L) the diameter of the handle is likely the problem. Seems to me the fitment would have been noted in the catalog. I sure wish I had known this before having the handles nickel plated. |
10-21-2020, 11:42 AM | #2 |
Re: Window Riser Handles and "Show Quality" Nickel Plated Escutcheons
I feel your pain. Customers do not realize that we pretty much need to assemble their vehicle twice during the restoration process. If you don't mock-fit everything, it will haunt you in the end. Assembling twice costs money too.
10-21-2020, 12:31 PM | #3 |
Wonder if you cross drill a piece of key stock for the pin and then shave down the handle barrel. The rest of the handle may be in the way.
I have a friend who is a retired tool and die maker with a nice shop. Time to pay him a visit. Turning it down would require removing the chrome under the nickel exposing bare metal. The cost of having them nickel plated again is minimal. The second picture shows the furthest the handle will go into the escutcheon. Last edited by dmaxweb; 10-21-2020 at 12:38 PM. |
10-21-2020, 12:39 PM | #4 |
The area of the handle, if turned down and under the escutcheons would not be visible. Would you really need to replace them?
10-21-2020, 12:48 PM | #5 |
Is it the plating that made it too large to fit the escutcheon?
10-21-2020, 12:54 PM | #6 |
10-21-2020, 12:59 PM | #7 |
10-21-2020, 02:03 PM | #8 |
https://www.brattons.com/show-qualit...scutcheon.html
"Will only work with original handles. Current reproductions are too large to fit into this escutcheon." No idea when they added that, though. Could've been yesterday. And apparently not in the print catalog. |
10-21-2020, 03:36 PM | #9 | |
10-21-2020, 06:39 PM | #10 |
If you are careful the handle parts that are visible won't get scratched or damaged. BTW who is doing the plating so reasonably?
10-22-2020, 05:01 AM | #11 |
Sometimes it helps to sleep on situations.
It occurred to me that rather than making the oversize China handle fit the correct size U.S. escutcheon, I will just get a pair of China escutcheons (which do fit the China handles) and butler plate them. The stamping is not as crisp as the U.S. ones but really not noticable. Much simpler solution to the problem and a heads-up to any of you. |
10-22-2020, 07:49 AM | #12 |
I will say, I had to replace a couple of my scroll window riser handles and the quality of the new ones is far, far superior to the old ones that broke on me. They were paper thin vintique repros. I'm frankly amazed they worked at all before they snapped.
10-22-2020, 08:05 AM | #13 | |
Oh well, lesson learned and moving on to the next hurdle whatever that might be. |
10-22-2020, 07:32 PM | #14 |
Do your scroll window handles have the "ridge" down the back? I've had someone tell me that the originals did not have this. I can't tell by the drawing in the JS.
10-23-2020, 06:44 AM | #15 |
I can't speak for the originals but I don't think mine have that ridge. I've also never seen that before. I can check later today. I bought a couple repros a few years ago now so it was probably a different batch.
10-23-2020, 07:26 AM | #16 | |
Also attached here is a picture of the door latch handles I ordered at the same time. They have a soft raised area with a taper. They certainly don't match the window handles. Are they closer to original or am I going to be even more upset? |
10-23-2020, 08:35 AM | #17 |
I'll have to take a good look at mine when I get home. Mine also might not be the one to base anything off of since they are probably a mismatched set of repro parts. I'm pretty sure the ones I got came from Snyders in 2015.
10-23-2020, 08:52 AM | #18 |
I just spoke with Snyders. They indicated their window handle does "not look exactly like the picture [on their website] and it does have the vein down the middle."
Disappointing about the part but kudos to them for being pleasant and helpful. |
10-23-2020, 12:56 PM | #19 |
Does anyone have a picture(s) of an original scroll handle to post?
Thanks |
10-25-2020, 01:45 AM | #20 |
Here you go.
1928 Roadster (CA67) 1931 Deluxe Coupe RHD 1931 Victoria RHD Model A's don't leak oil they just mark their territory. |
