03-29-2016, 12:51 AM | #21 |
Re: Castle nuts and cotter keys
03-29-2016, 01:07 AM | #22 |
03-29-2016, 02:20 AM | #23 |
One of the biggest improvements over Castle & cotter is what Mercedes uses for the bearing nuts on front axles. The Castle nut is replaced by a horseshoe nut with a screw passing thru the two open legs of the shoe. Once the nut is tightened to just right amount for the bearing, the screw is tightened to lock the nut in place. Probably a tad more expensive, but there is no too loose or over tight situation to get the castle to line up with the hole thru the spindle !!!
03-29-2016, 07:28 AM | #24 | |
I've had bad luck using lock washers on cast. Maybe I was using cruddy washers, maybe it was hard cast, it was twenty ish years ago now so I can't remember even what tractor it was on, but I tried washers over the wire and got bit, had to go back and wire it up. Never tried it again. |
03-29-2016, 10:48 AM | #25 | |
Bill W.
03-30-2016, 06:27 PM | #26 |
03-30-2016, 07:49 PM | #27 |
I always use them.
03-30-2016, 11:03 PM | #28 |
I got tired of hunting down the exact cotter pin, I built this:
03-30-2016, 11:27 PM | #29 |
Just use a nail. Drive it through and hit it with a hammer to bent it a bit.
As a professional auto tech, I saw this method a lot. Always use a new pin, it's a pin to me, a key goes in a slot. To Ian, when I raced bikes in the 70's, we had to safety wire everything and I mean everything. |
03-31-2016, 07:49 AM | #30 |
I realize we're not talking about aircraft maintenance, but in my experience, castellated nuts are used when a minimum of torque is required...hence a cotter pin to keep the castellated nut in place. A lock-washer is designed to be used with a plain nuts when self-locking or castellated type nuts are not applicable. The spring action of the washer prevents the nut from becoming loose. To me, it sounds like the castellated nut has a specific purpose if installed on a certain component for a specific function. Just my two cents....
