03-05-2021, 03:53 AM | #1 |
1952-59 ford social group @ hamb-bone
How in the world do you get in? I got in once and cannot figure how to do it again.
Are they checking at the door now ... CORNFUSED AND AGITATED IN W(BY GOD)V ...
***** We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ... |
03-05-2021, 08:11 AM | #2 |
Re: 1952-59 ford social group @ hamb-bone
You have to check in with the three-headed monster first!
Now let's se if I can get these steps in the right order and maybe add a couple of pictures to go with them. 1. Click on the tab with three heads to get a list. 2. Click on the words SOCIAL FORUMS to get another list. 3. Click on the word Brands to get the list of forums identified by vehicle brand. 4. Click on the words 1952-59 Ford Social Group. If you are already a member, you see the posts in that group. 5. You need to join the group if you see (You have insufficient privileges to post here.) Click on the words Social Forum Tools to get another list. 6. Click on the words JOIN SOCIAL FORUM. Now you are a member and can see posts in the forum. Just close the window when you are done with the posts. You can drop your membership in the the group if you go back to Social Forum Tools and click the words LEAVE SOCIAL FORUM. Now let's see if I can get the pictures in here in the correct order. It is tricky at first to get into the HAMB social forum, but it is easier to post pictures over there. Both places have a bunch of great guys and great information! |
03-05-2021, 08:36 AM | #3 |
CORNFUSED! HEE-HAW! Start here..
03-05-2021, 10:01 AM | #4 |
DAMN!
Prison release was easier ...
03-05-2021, 10:06 AM | #5 |
THANX GUYS!
What I am trying to find is retro-fitting self adjusters on pre- 1958 FORD. In 1958 FORD supposedly installed self-adjusters on high trim FORD - MERC (1957) - LINC. No mention in either the 49/59 MPC . First years used shows 1961.
03-05-2021, 10:11 AM | #6 |
03-05-2021, 02:11 PM | #7 |
... got in ...
Waited for lunch and they left a window open ...
03-06-2021, 02:58 AM | #8 |
What it all comes down to on the self adjusters is to find a later model Ford that uses the same brake shoes then you use the same hardware and adjuster kits. The first one we did in the Group was the 1952-54 Fords they use the same shoes as 1967-72 Mustangs so that made it easy. One little trick is to use the Rock Auto catalog online when you click on a brake shoe part number you get a pop up showing other cars that use the same shoes self adjusters became more standard about 1962 and later.
03-06-2021, 09:13 AM | #9 | |
And now you are saying to find a later shoe(s) with later webbing that will accept the self-adjusting components. Makes sense to me. But if the FORD has 11" shoes and the MUST has 10" shoes, will the cable be long enough for the earlier shoe? I just noticed you say your social group has a FAQ which I failed to notice. Is there more info there? FORD actually began install in 1958, but there is nothing in the MPC about it or the SHOP MANUAL(S). MERC has the info. Anywho, I began to think (not common) that a front disc swap needs the rear self-adjusters to keep the drums in proper adjustment so as not to over work the disc. THANX!
03-08-2021, 09:47 AM | #10 | |
03-08-2021, 09:59 AM | #11 | |
THANX again as I think I am about to speed on retro-fitting. Now one has to worry about finding a correct/undamaged set of later shoes that can be re-lined.
03-08-2021, 08:48 PM | #12 |
The TBirds used 11 inch shoes. There is a write up in the Early Bird magazine on self adjusting conversion with part numbers. I have a copy if your interested. Will send snail mail
03-07-2021, 03:01 AM | #13 |
This is a page from my '58 Edsel Service manual.
Frank '35 Ford Model 51 '48 Ford F3 '54 Ford Tudor Mainline |
12-28-2021, 11:49 AM | #14 |
12-30-2021, 09:23 AM | #15 |
I had the 4 piston KH brakes on a 67 Galaxie. The calipers were massive, had special steel wheels to clear them and they were 15 inch. Also had a 67 Cyclone with the 4 piston KH, they were not as large, and a regular 14-inch rim fit. Don't know if they would swap over to Thunderbird. A person can rebuild calipers but is it even possible to buy a brake rotor made in the USA?
12-30-2021, 01:50 PM | #16 | |
12" BIRD ROTOR on MUST -
01-03-2022, 07:57 AM | #17 |
AHA!
I see we are returning to THE OLDE DISAPPEARING ILL SYNDROME ... PHOTO REINSERTED (NOTE- This example was overkill (IMO) as it was intended for racing but shows how it was done in the day) I would consider this setup if one was not interested in finding old KH take-of parts - - https://www.wilwood.com/BrakeKits/Br...emno=140-13653 (I would use their foundation brake and adapter kit but be careful of valving). Or the KH SWAP that allows the retention of the OEM SPINDLE (HILL'S is one vendor).
12-31-2021, 04:05 AM | #18 | |
CENTRIC (STOP-TECH) is a class act IMO. All is manufactured in CHINA but it is better in quality than FORD and/or MOTORCRAFT. I just completely re-did my ESCAPE and I was amazed at the quality. Now on a swap like being discussed here, I would try to find NOS or take-off calipers/MC/valving as I don't want some re-design. CENTRIC offers the rotor hat only and you would keep the original hubs, so no worry there.
