Old 06-29-2021, 11:35 AM   #1
fastroadster
Default Towing my "A"
Any problems towing my 29 pickup with the visor? Should I load it backwards on trailer? Don't want problems with damaging visor.
fastroadster is offline   Reply With Quote
Old 06-29-2021, 11:59 AM   #2
J Franklin
J Franklin's Avatar
Default Re: Towing my "A"
How fast are you planning to drive!
Old 06-29-2021, 11:59 AM   #3
Big hammer
Facing forward keep it under 100mph ��
get a bigger hammer tap done
Old 06-29-2021, 12:06 PM   #4
700rpm
700rpm's Avatar
Tape down your windshield wiper blade.
Ray Horton, Portland, OR
Old 06-29-2021, 12:21 PM   #5
LeonardS
I towed my 28 pickup from Illinois and did have to stop and tighten the visor. I’m not sure if it was from the wind currents off my Suburban or possibly it was a little loose before I left.
LeonardS is offline   Reply With Quote
Old 06-29-2021, 12:44 PM   #6
fastroadster
Thanks everyone. Not planning to haul ass.... lol Just driving a couple of hundred miles 60-65
Old 06-29-2021, 03:49 PM   #7
700rpm
700rpm's Avatar
Strap it down on on the trailer on all four corners, but not in the middle of the front axle.
Old 06-29-2021, 04:02 PM   #8
Kinner
Just saw a video on trailering a classic car. He likes forward incase a door pops open less damage.
Kinner is offline   Reply With Quote
Old 06-29-2021, 05:28 PM   #9
Y-Blockhead
Y-Blockhead's Avatar
Good idea unless you are towing a Fordor...
Old 06-29-2021, 06:28 PM   #10
Marcus
Marcus's Avatar
Fastroadster - I would NOT recommend towing by the visor - GRIN - however, I trailer Ol' Clyde, '29 CCPU, routinely all about with absolutely no problems facing forward. I strap it down on the front axle, outboard of the spring perches (each side), and as far out on the rear axle as possible. I drive whatever the speed limit happens to be - I've owned the truck since forever......
WARM REGARDS, MARCUS
Marcus is offline   Reply With Quote
Old 06-30-2021, 06:35 AM   #11
dave in australia
Cars are driven forwards up to 65MPH without a problem, so towing them on a trailer facing forward would be no extra problems.
dave in australia is offline   Reply With Quote
Old 06-30-2021, 07:16 AM   #12
eagle
eagle's Avatar
It's simple enough to run a couple of straps over the top of the car with rags under them.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 06-30-2021, 08:58 AM   #13
Steve in Denver
Steve in Denver's Avatar
Use good straps or come-alongs, do NOT trust the straps on U-Haul trailers. I have tried twice and both times they came loose, maybe they don't like 16 inch tires. I know the come-alongs are not coming loose.
Steve in Denver is offline   Reply With Quote
Old 06-30-2021, 05:48 PM   #14
MickyD
MickyD's Avatar
You can never go wrong by chock blocking all 4 tires and tying down all 4 corners of the vehicle from underneath. I wish I still had all the cars and trucks I have brought home on a trailer.
MickyD is offline   Reply With Quote
Old 06-30-2021, 09:26 PM   #15
denis4x4
denis4x4's Avatar
1700 miles last week with no issues. Ran 70 MPH with the front facing forward on an open trailer. I have a tongue weight scale and have a single chock in the preferred position for each car for a balanced ride.
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
