Old 01-21-2022, 08:20 PM   #1
IndyA
Default Iron Stains on block ???
I had a slight leak at the radiator neck which dripped down the inlet neck and would like to know if there's a way I can get rid of the stain without damage to the nice Ford Green which the rebuilder put during the rebuild. Thanks for your help. Indy A
IndyA is offline   Reply With Quote
Old 01-21-2022, 08:30 PM   #2
nkaminar
nkaminar's Avatar
Default Re: Iron Stains on block ???
I would try a little Bar Keeper's Friend, available in hardware and grocery stores. Make a paste and rub it on the stain. Let it sit for a few minutes then rinse it off with water. I have used this to remove rust stains on a variety of surfaces.
Old 01-21-2022, 09:02 PM   #3
eagle
eagle's Avatar
Whink Rust Stain remover will do the job easily without damaging the paint.
Old 01-21-2022, 11:04 PM   #4
bruceincam
bruceincam's Avatar
If you haven't already done so, try a damp rag first --- it may just wipe off with water.
bruceincam is offline   Reply With Quote
