Old 07-11-2021, 07:05 PM   #1
rfequity
Default top of radiator shroud hot
Is it normal after an in town drive that the top of the shroud around the cap would be too hot to touch? Its in the 80’s outside and very humid. Also, i notice the engine seems alot more sluggish when its humid.
rfequity is offline   Reply With Quote
Old 07-11-2021, 07:14 PM   #2
WHN
Default Re: top of radiator shroud hot
I’ve never had it that hot. Just warm to the touch.
WHN is offline   Reply With Quote
Old 07-11-2021, 07:19 PM   #3
ETAModel
Hot to the touch is a relative term. A friend worked in a dental lab making teeth and he can hold a fresh cast lead bullet.
The cap on the 30 fordor i drive gets pretty warm, almost too warm to handle, but idk how hot that is.
Don't they call the model A "Hotwater Fords"?
ETAModel is offline   Reply With Quote
Old 07-11-2021, 09:09 PM   #4
1crosscut
1crosscut's Avatar
Use a deal meat thermometer placed into the coolant to check the temperature.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 07-12-2021, 08:24 AM   #5
1931 flamingo
1931 flamingo's Avatar
Get a "point and shoot" temp gun at Harbor Freight and get back to us.
Paul in CT
Old 07-12-2021, 08:07 PM   #6
Richard in Anaheim CA
Richard in Anaheim CA's Avatar
It's unlikely you actually mean shroud. They only came on '28 and were usually thrown away with the engine pans. Do you actually mean radiator cap, top tank of the radiator, or radiator shell?
The radiator is intended to dissipate heat. Do you usually just drive to the 7-11 and home and this time actually put 10 or 15 miles on it? It will be too hot to touch, probably 140-170 degrees.
Richard in Anaheim CA is offline   Reply With Quote
Old 07-12-2021, 08:31 PM   #7
rfequity
Yes, i meant the “shell”.
Old 07-12-2021, 09:24 PM   #8
abachman3
abachman3's Avatar
The top of the radiator shell is being heated by radiant heat dissipating from the radiator. When the engine is turned off, the engine generally gets warmer as does the radiator, as there is no more cooling happening through the radiator. So, yes I would say, even from personal experience, that the top of the shell does get quite hot. I have never checked the actual temperature, but know that mine will get too hot to keep your hand on it.
abachman3 is offline   Reply With Quote
Old 07-13-2021, 07:41 AM   #9
1928Mik
1928Mik's Avatar
I'm with abachman3. Once you shut down, the top of the shell will normally get hotter for a bit...
1928 Niagara Blue Phaeton
1972 Olds 442 Convertible
1979 MGB
-Life's Too Short To Drive Boring Cars-
1928Mik is offline   Reply With Quote
Old 07-13-2021, 09:52 AM   #10
rfequity
Thank you all. That all makes sense. Thanks again for the help.
Old 07-13-2021, 11:19 AM   #11
WHN
The thermo syphon continues with the engine not running. Unlike a more modern car, the water pump is just there for added help with the engine cooling. Modern cars have the water pump installed at the inlet to the engine. Forcing the coolant into your motor. Model A’s pump is mounted at the outlet of the engine. As your Model A engine warms up, the coolant starts moving out and into the radiator. Thermo Syphon. Cools down, sinking to the bottom of radiator and back into the engine. Pushing the warmer water up and out the top of your engine. I think what you are seeing happen when the engine is shut off is the now lack of air moving over and around you radiator and engine. Engine fan is no longer turning and the air from your car moving forward is not going thru the radiator.
Syphon should still be working trying to cool the system. I would think that to hot to touch might indicate a cooling problem.
Old 07-13-2021, 11:22 AM   #12
katy
katy's Avatar
As long as it's not boiling.
