Old 12-16-2012, 02:49 PM   #21
DavidG
DavidG's Avatar
Default Re: 32 Parts - How to tell Original from Reproduction??
The very earliest versions of the deluxe coupe sun visors did not have the end caps. they were added as a running change.
Old 12-16-2012, 04:23 PM   #22
NealinCA
NealinCA's Avatar
Thanks for the info. There is no Drake name molded into the spokes of the wheel...so that is still undetermined.
Thanks again...and I am sure I will have more questions...
Neal
NealinCA is offline   Reply With Quote
Old 12-16-2012, 06:27 PM   #23
DavidG
DavidG's Avatar
One last thought on the sun visors. Whomever covered them used a non-original stitch pattern. Originally, the stitch line was up tight around the inside of the wire frame, not out in the middle like in the photo.
Old 12-16-2012, 07:02 PM   #24
G.M.
If you can't tell if it's a repro or not don't worry about it. G.M.
www.fordcollector.com
Old 04-17-2013, 11:15 PM   #25
NealinCA
NealinCA's Avatar
Here's another part I am trying to figure out...I think 4-cylinder dash control for adjusting the carb...but the knob says CHOKE? Does it do both?
Can anyone verify?
Thanks,
Neal
Old 04-17-2013, 11:22 PM   #26
Charlie Stephens
Can anyone verify?
Thanks,
Neal
If you pull the knob it chokes, if you twist it it adjusts the carb. Same idea as the choke rod on a Model A except it is a cable.
Charlie Stephens
Old 04-17-2013, 11:23 PM   #27
NealinCA
NealinCA's Avatar
Thanks Charlie...I kinda thought that, but I've never been around a 32 4-cyl.
Thanks,
Neal
Old 04-18-2013, 02:37 PM   #28
32phil
I would avoid twisting the choke cable, pulling on it is OK but they don't like the twisting too much. The twistin' is what killed a lot of those choke cables.
On my B I leave the adjustment closed, pull the choke, crank the starter a bit, release the choke and it usually starts, then I pull the choke back out a little and hold it for a minute or so till it starts to warm up, then I let the choke open all the way...no twistin'..... just pullin' then holdin' till it warms and then lettin' go
Early Ford Lock & Key Service
http://www.fordbarn.com/forum/showthread.php?t=46583
32phil is offline   Reply With Quote
Old 04-18-2013, 02:46 PM   #29
DavidG
DavidG's Avatar
With respect, it's the outer conduit that fails frequently and not the core. I can't recall seeing a failed choke cable core. For what it's worth, the owner's manual starting procedure is somewhat different, but I've found it to be effective.
Old 04-18-2013, 09:02 PM   #30
Randall
Randall's Avatar
[IMG][/IMG]Are these repops?
Randall is offline   Reply With Quote
Old 04-18-2013, 09:12 PM   #31
DavidG
DavidG's Avatar
I think we covered this earlier in this thread, but no matter. Stick your finger in the curl and if you feel a large washer inside about midway, they're reproductions. Judging from the size of the knuckles on the bumpers in your photos, you will not encounter a washer.
Old 04-18-2013, 09:21 PM   #32
Randall
Randall's Avatar
Thanks David ,wasn't sure where the washer would be.These was on a buddys model a with a B mdl grill,rad and head lights.
Old 04-18-2013, 09:28 PM   #33
Randall
Randall's Avatar
[IMG][/IMG]Will be going on this when I get it finished!
Old 04-19-2013, 10:50 AM   #34
redo32
Original bumpers are spring steel, the heat treating leaves a distinct pattern and texture on the back side. These bumpers are smooth on the back, leading one to surmise they are cold rolled repos.
redo32 is offline   Reply With Quote
