Old 05-04-2017, 06:49 PM   #21
Phil Brown
Phil Brown's Avatar
Default Re: Horsepower
Then there is this way
Phil Brown is offline   Reply With Quote
Old 05-04-2017, 06:55 PM   #22
MikeK
MikeK's Avatar
Is there a waste gate?
MikeK is offline   Reply With Quote
Old 05-04-2017, 06:57 PM   #23
biggieou
This just made my day!
Sent from my SM-N920V using Tapatalk
1931 Model A Victoria
1950 Mercury 8
Member: MAFCA, MARC, Northern Ohio Model A Club
www.northernohiomodela.com
biggieou is offline   Reply With Quote
Old 05-04-2017, 07:15 PM   #24
Phil Brown
Phil Brown's Avatar
Yea, its internal. part of the exhaust housing
Old 05-04-2017, 08:00 PM   #25
tinkirk
tinkirk's Avatar
Yes i thought about something for a booster but never played with that kind of stuff
I put a 327 gear in just want to stay with traffic
Oh i do have a 6.0 snyder head but who knows where the compression will end up
I will be milling that to be able to get as close to the pistons as close that will be save
I've been told i could get by with .025 between them but we will see
Hopefully i get the parts back from my machine guy tomorrow
Then the fun starts
tinkirk is offline   Reply With Quote
Old 05-04-2017, 08:10 PM   #26
tinkirk
tinkirk's Avatar
Originally Posted by BRENT in 10-uh-C View Post
To answer you specifically; a 6½:1 high-compression head, a Stipe IB340 camshaft, oversized ( 1.750" ) intake valves with the valve bowls opened up, port match the intake and open up the draw-tube to 1.250" with a flowed Model-B carb, and a rebuilt distributer with a Stipe cam and a good coil will get you very close on a dyno. Other items such as an exhaust header, 2bbl carburetor, hotter camshaft, etc. will give you a little more power, but in my opinion look for ways to increase torque instead of adding Hp. Torque will allow you to pull a higher gear ratio which increases mph.
Brent thankyou for your advice and i agree but with horsepower comes more torque also torque is what gets you moving and horsepower takes over after that
Not building a race motor just looking to go down the road at a respectable speed to not be an henderance to others
Old 05-04-2017, 08:20 PM   #27
Synchro909
Synchro909's Avatar
Which Stipe 340 cam? If it is the Stipe IB 340 you won't be making that much horsepower with what you've spec'd. (IB stands for 'Improved B'). If you get one of the the Stipe Road Runners, like the RR340, which is a more agressive cam, you may reach your coveted 70hp. You can see the spec's for the IB340 and the RR340 cams on Vince's website.
Keep in mind a lot of horsepower or torque in an A is useless unless it has a very wide power band, necessary because you have only three widely spaced forward gear ratios. Unfortunately, mods to increase power inevitably raise the RPM for power peaks and narrow the band as a percentage of operating range. Increased HP also becomes diminished in effectiveness if the power peaks are thousands of RPM above stock because you will not be able to shift that non-synchro trans quickly enough to keep on top of that power band.
All very true! For optimum performance, you need to maximise the area under the power/RPM graph. Going for max horsepower raises the curve for a narrow rev range, sure and that increases the area under the curve at that point but also makes it lower elsewhere which reduces the area on other parts of the power curve. You win in one place, you lose elsewhere so it's a balancing act.
Old 05-04-2017, 08:27 PM   #28
tinkirk
tinkirk's Avatar
Yes very true
I'm new to these little motors learning by reading and asking
Talked stipes and told them what i had and the future induction
The IB340 is what he suggested
I thought about the RR340 but not knowing I followed his lead
Terry
Old 05-04-2017, 08:42 PM   #29
Towd56
What's that make for HP?
Towd56 is offline   Reply With Quote
Old 05-04-2017, 10:12 PM   #30
Phil Brown
Phil Brown's Avatar
Never got it to the dyno (only run stand time ) before someone else had to have it for his little hot rod and bought it from me. I have talked to him and he said that "when you leave a stop light you know that it's not a stock Model A"
I have no doubt that if you get greedy and turn it up it will make enough HP to push the crank out of the bottom
Old 05-04-2017, 11:00 PM   #31
Mike V. Florida
Mike V. Florida's Avatar
Speed = money, how much do you have to spend?
Old 05-04-2017, 11:18 PM   #32
Brendan
Brendan's Avatar
i just got mine to hit on all 4...lol
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 05-05-2017, 04:21 AM   #33
dumb person
dumb person's Avatar
Isn't doubling the RPM of a model A engine like souping up a rotary? The flywheel becomes a grenade? Just thinking about that huge heavy flywheel in there turning at high speed and the forces on it, when the car changed direction it wants to rotate on the same plane it's on and parts company with the crank?
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
Old 05-05-2017, 04:27 AM   #34
Towd56
I guess that's a pretty fair answer! A neat set up.
Old 05-05-2017, 06:25 AM   #35
mshmodela
mshmodela's Avatar
They can only rev to fast...
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 05-05-2017, 08:56 AM   #36
kenb43
With all the perceived need for power and speed, remember that ya gotta stop the thing somehow. Don't forget to pay attention to the brakes.
kenb43 is offline   Reply With Quote
Old 05-05-2017, 09:02 AM   #37
johnneilson
This is going to excess, but fun.
Stops revving about 7300 rpm.
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is online now   Reply With Quote
Old 05-05-2017, 09:35 AM   #38
zzlegend
zzlegend's Avatar
Now that's what I am talking about. Thanks John.
zzlegend is offline   Reply With Quote
Old 05-05-2017, 02:01 PM   #39
hardtimes
hardtimes's Avatar
Yup, think safety always !!
I'm working on a 'parachute' project for Phil and John's rides !
Old 05-05-2017, 02:15 PM   #40
30 Tudor
30 Tudor's Avatar
So what is a safe steady speed for the engine mph with 3.27 rear end, burlington crank,
with inserts and rods from antiqueengines, 6.0 head, stipes cam, pistons with plenty of clearance and a pair of heavy boots and a tank of gas!
What is a safe rpm range, something in the realm of "normal"
30 Tudor is offline   Reply With Quote
