09-19-2021, 10:49 AM | #1 |
gasket sealent
I just took the Zenith carb apart to replace the large paper gasket. Do I have to put some stuff on it like Permatex to seal it properly? Thanks
09-19-2021, 12:19 PM | #2 |
Re: gasket sealent
No.
I noticed the harder I work the luckier I get! |
09-19-2021, 01:44 PM | #3 |
Re: gasket sealent
Usually no. Make sure the surfaces are flat and not scored.
09-19-2021, 03:44 PM | #4 |
Re: gasket sealent
I've put in may carb gaskets and always without sealant.
09-19-2021, 05:08 PM | #5 |
Re: gasket sealent
Ok guys. I won't put anything on it. The surfaces are flat and clean as can be. Thanks
09-19-2021, 07:43 PM | #6 |
Re: gasket sealent
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
09-19-2021, 08:24 PM | #7 |
Re: gasket sealent
Old mechanic’s method: I used to put a thin layer of grease on the top and bottom gasket surfaces,just in case there was a scratch or nick on one of those surfaces, thinking that since they weren’t pressurized that might stop any leaks. But I eventually learned that wasn’t necessary. The gaskets seem to be adequate.
09-20-2021, 07:01 AM | #8 |
Re: gasket sealent
Thanks everyone for your replies. I think I finally found the problem with my leaking gas. It isn't the old paper gasket but the stupid Chinese made fuel shut off valve letting gas in to the carb even though it is shut off. I pulled the gas line off the carb and over night it dripped a little too much gas into my container. Shouldn't the shut off valve totally shut off the gas and not let any keep flowing out? I think I just replaced this valve two years ago and it was great as far as being able to turn easy but now it has gotten real difficult to turn. I think if I have to replace this every couple of years I'll just sell it. It's not a hard job but it's very frustrating.
09-20-2021, 09:13 AM | #9 | |
Re: gasket sealent
Selling your car is a little extreme if you enjoy your Model A at all. How about installing a ball valve from Bratton's instead? https://www.brattons.com/30-31GAS-LI...uctinfo/13350/ FWIW, Bratton's tank shut off valve https://www.brattons.com/FUEL-SHUT-O...uctinfo/13160/ is Made in USA and Bratton's (as far as I know) is the only vendor to offer a 3 year warranty.
Ruth "Sometimes you really DO need to read the whole thread" Last edited by Ruth; 09-20-2021 at 09:24 AM. |
09-20-2021, 10:25 AM | #10 |
Re: gasket sealent
Thanks Ruth. I'll look in to getting that cause that is what happened to my last valve. It eventually got so hard to turn.
09-20-2021, 10:34 AM | #11 |
Re: gasket sealent
Install a pencil filter...should keep any particles from entering the shutoff valve.
Thread Tools | |
Display Modes | |
