Old 09-24-2017, 02:13 PM   #1
Y-Blockhead
Y-Blockhead's Avatar
Default Flywheel Weight
Good morning, Dudes. I have a stock flywheel laying on the garage floor (good place for it!) and my neighbor tripped on it, and yells, "WTF does that thing weigh anyway?"
I said "Ya know, I have no idea" So I searched on Ford Barn and couldn't find the answer.
So... what do those Bad Boys weigh, anyway?
Old 09-24-2017, 02:19 PM   #2
Vic in E-TN
Default Re: Flywheel Weight
An uncut one weighs 63 lbs/
Vic
Vic in E-TN is offline   Reply With Quote
Old 09-24-2017, 02:21 PM   #3
Y-Blockhead
Vic
Thanks Vic
Old 09-24-2017, 11:32 PM   #4
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
?? You don't own a bathroom scale??
Old 09-25-2017, 12:06 AM   #5
Mike V. Florida
Mike V. Florida's Avatar
Engine parts and weights.
Old 09-25-2017, 12:36 AM   #6
Synchro909
Synchro909's Avatar
Originally Posted by Mike V. Florida View Post
Mike, I get a message saying "This site cannot be reached"
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 09-25-2017, 01:16 AM   #7
Dollar Bill
Dollar Bill's Avatar
I got the same thing - Not sure if this was what Mike was linking us to but it does provide some pretty interesting specs.
Select "Flywheel Specifications" in the menu or just scroll down toward the bottom of the page.
http://www.macsautoparts.com/store/model-a-specs/#fly
Weight 63 lbs., 4 oz. (Model B 52 to 55 lbs.)
Balance Within 15 in./oz.
Ring Gear Shoulder Diameter 12.470"
Ring Gear Outside Diameter 14.2"
Number of Ring Gear Teeth 112
Ring Gear to Starter Drive Ratio 11.2: 1
Flywheel Bolt Torque 65 foot pounds
Pilot bearing hole is concentric with crankshaft flange shoulder within .002" TIR (Total Indicator Reading).
Clutch mounting surface & clutch disc surface must run true to crankshaft within .005" TIR (Total Indicator Reading).Clutch mounting shoulder diameter must be concentric with crankshaft flange diameter within .005" TIR (Total Indicator Reading).
Flywheels provide momentum to keep the crankshaft spinning. As the flywheel spins faster, a vibration will occur if it’s out of balance. It’s best to have your flywheel, with clutch & pressure plate, balanced so that when you place in the clutch disc & reinstall the pressure plate it will retain balance.
I Love Anything That Turns Money Into Noise
Dollar Bill is offline   Reply With Quote
Old 09-25-2017, 01:34 AM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
https://www.fordbarn.com/forum/showt...+tom+wesenberg
Old 09-25-2017, 11:45 PM   #9
Mike V. Florida
Sorry about that guys, it worked for me but Tom posted the same information above.
Old 09-26-2017, 12:00 AM   #10
Y-Blockhead
Uh, yeah, I do. But since I have heart failure my scale sends my weight wirelessly to a registered nurse. I think she would freak out if my weight suddenly jumped 63# . She contacts me if my weight fluctuates 3# a day...
Sometimes it's better to just answer the questions...
Old 09-26-2017, 09:47 AM   #11
Bob Bidonde
Bob Bidonde's Avatar
"Pilot bearing hole is concentric with crankshaft flange shoulder within .002" TIR (Total Indicator Reading)."
TIR = Total Indicated Runout
Bob Bidonde
