Old 11-30-2021, 01:58 PM   #1
ModelAJim
ModelAJim's Avatar
Default What are these holes for in Sub Rail Extensions?
What are these 2 holes for in the 30-31 Sub Rail Ext? were they rivet holes or bolt holes? to attach subframe to cowl?
I see the small rives on the sub rail flange but wondered about these 2 bigger ones?
Thanks!
ModelAJim is offline   Reply With Quote
Old 11-30-2021, 02:30 PM   #2
Oldbluoval
Oldbluoval's Avatar
Default Re: What are these holes for in Sub Rail Extensions?
Body bolts to the fitting riveted to frame
Oldbluoval is offline   Reply With Quote
Old 12-02-2021, 06:11 AM   #3
ModelAJim
ModelAJim's Avatar
Makes sense! Thank you !
Old 12-02-2021, 07:59 AM   #4
fundytides
fundytides's Avatar
Don't forget the wooden block in between the body and the frame bracket.
fundytides is offline   Reply With Quote
